Mass Storage Device example
Description
This example implements a mass storage class device that operates on a FAT12 volume stored in internal RAM. The size of this volume is set by the constant DATA_RAM_PHYSICAL_SIZE defined in DataRam.h
Compiler build configurations
The software that makes up this example is designed to run on many different development boards. Therefore the compiler must be configured to build an image that is targeted to the development board you are using. This section explains how to set these build configurations for each of the supported compilers.
LPCXpresso IDE
Configure projects
  right click on the BSP project in the project explorer window
  click Build Configurations->Set Active->(see configuration in table below)
  repeat these steps with the CDL, nxpUSBlib, and Example_MassStorageDevice
Configure MCU
  right click on the Example_MassStorageDevice project in the project explorer window
  click Properties->C/C++ Build->MCU settings->(see configuration in table below)
Configure the indexer
   click Window->Preferences->C/C++->Indexer->Use active build configuration
BSP
CDL
nxpUSBlib
MCU
LPC1850  / Hitex
LPC18xx_HITEX
LPC18xx
LPC18xx_Device
LPC18xx
LPC1850
LPC4330  / Xplorer
LPC4330_Xplorer
LPC18xx
LPC18xx_Device
LPC18xx
LPC4330
LPC4350  / Element14
LPC1435_ELEMENT14
LPC18xx
LPC18xx_Device
LPC18xx
LPC4350
LPC11U14 / LPCXpresso
LPC11Uxx_LPCXpressoRevB
LPC11Uxx
LPC11Uxx_Device
LPC11Uxx
LPC11U14
LPC11U14 / MCB1000
LPC11u14_MCB1000
LPC11Uxx
LPC11Uxx_Device
LPC11Uxx
LPC11U14
LPC1768  / MCB1700
LPC1768_MCB1700
LPC17xx
LPC17xx_Device
LPC17xx
LPC1768
LPC1768  / LPCXpresso
LPC17xx_LPCXpressoRevB
LPC17xx
LPC17xx_Device
LPC17xx
LPC1768
NOTE:
The LPC18xx CDL is used with boards that hold LPC43xx parts. This is done because the LPC43xx CDL is currently experimental. The LPC18xx USB library is used because both parts share the same controller.
Keil uVision 4 IDE
Configure a Batch Build
  click on Project->Batch Build...
  expand the BSP project to display a list of project targets
  select the project target by checking the appropriate checkbox (see target list in table below)
  repeat these steps with the CDL, nxpUSBlib_Device, and Example_MassStorageDevice
BSP
CDL
nxpUSBlib_Device
LPC1850  / Hitex
HITEX1800
LPC18xx
LPC18xx_Device
HITEX1800
LPC1768  / MCB1700
MCB1700
LPC17xx
LPC17xx_Device
MCB1700
LPC11U14 / MCB1000
MCB1000
LPC11Uxx
LPC11Uxx_Device
MCB1000
Board connections and configurations
LPC18xx_HITEX (LPC1850 Hitex Evaluation Board)  older A2 design
schematic ./BSP/schematics/HITEX_SCM_LPC1850EVA-A2-2.pdf
Connect the JTAG to the 20 pin receptacle marked X4 JTAG
Connect the type-B end of a USB cable to the receptacle marked X2. Plug the type-A end of this cable into a PC
LPC18xx_HITEX (LPC1850 Hitex Evaluation Board)  newer A4 design
schematic ./BSP/schematics/HITEX_Final_LPC1850EVA-A3.pdf
LPC4330_Xplorer (NGX Xplorer Evaluation Board with LPC4330)
Connect the JTAG to the 10 pin receptacle marked J2
Connect the micro-b end of a USB cable to the receptacle marked USB0. Plug the type-A end of this cable into a PC
LPC1435_ELEMENT14 (Element 14 gaming board with LPC4350)
Connect the JTAG to the 10 pin receptacle marked J6
Connect one end of a type-A to type-A USB cable to the receptacle marked USB0. Plug the other end of this cable into a PC
LPC11u14_MCB1000 (Keil MCB1000 development board)
schematic: ./BSP/schematics/mcb1000-schematics.pdf
Jumpers:
  J4 = 2-3      (UCON - PIO0_6 pulls D+ high)
  J2 = 1-2          (VDD  - core power)
  J5 not installed  (ISP  - ISP via COMM)
  J6 not installed  (RST  - ISP via COMM)
Connect the JTAG debugger to the 10 pin Cortex Debug connector labeled J3
Connect the type-B end of a USB cable to the type-B recepticle and the type-A end of the cable to the USB receptacle on a PC
Once the USB cable is connected to the board the following LEDs should be illuminated:
    Power
    All 8 LEDs in PIO2
LPC1768_MCB1700 (Keil MCB1700 development board)
schematic: ./BSP/schematics/mcb1700-schematics.pdf
Jumpers:
  E/U    = 1-2  (Ethernet/USB)
  UMODE  = 1-2  (USB Device Mode)
  D-     = Device
  D+     = Device
  VBUS   = 1-2
  VDDIO  = 1-2
  VDDREG = 1-2
Connect the JTAG debugger to the 20 pin JTAG or 10 pin Cortex Debug connector.
Connect the type-B end of a USB cable to the type-B recepticle labeled 'Device' and the type-A end of the cable to the USB receptacle on a PC. Once the USB cable is connected to the board the following LEDs should be illuminated:
    Power
    100MHz
    USC (LED indicates a USB soft connect from P2.9)
LPC11Uxx_LPCXpressoRevB (LPCXpresso LPC11Uxx on the LPCXpresso Rev B base board)
schematic: ./BSP/schematics/lpcxpresso.lpc11u14.schematic.pdf
Running this example on the LPCXpresso LPC11U14 can be done one of two ways:
1. LPCXpresso LPC11U14 stand-alone
      Connect the type-B end of a USB cable to the mini receptacle on the LPCXpresso board labeled J8 and the type-A end to the USB receptacle on a PC
2. LPCXpresso LPC11U14 plugged into the LPCXpresso base board Rev B
      Plug the LPCXpresso LPC11U14 board into the connector labeled J4 on a LPCXpresso base board Rev B
      Configure the base board according to the user's guide from Embedded Artists
      Connect the mini type-B end of a USB cable to the receptacle on the base board labeled X1 and the type-A end to the USB receptacle on a PC
          LED25  (vbus)
         LED26  (3.3v rail)
For both configurations the JTAG debugger is connected to the mini USB receptacle labeled J3 on the LPCXpresso LPC11U14 board
LPC17xx_LPCXpressoRevB (LPCXpresso LPC17xx on the LPCXpresso Rev B base board)
schematic: ./BSP/schematics/LPCXpressoLPC1769revB.pdf
Running this example on the LPCXpresso LPC1769 can be done one of two ways:
1. LPCXpresso LPC1769 stand-alone. Solder a type-B USB receptacle onto the board and wire it up. See included schematics for details. Connect the type-B end of a USB cable to the receptacle on the LPCXpresso board and the type-A end to the USB receptacle on a PC
2. LPCXpresso LPC1769 plugged into the LPCXpresso base board Rev B. Plug the LPCXpresso LPC1769 board into the connector labeled J4 on a LPCXpresso base board Rev B. Configure the base board according to the users guide from Embedded Artists. Connect the mini type-B end of a USB cable to the receptacle on the base board labeled X1 and the type-A end to the USB receptacle on a PC.
      LED25  (vbus)
      LED26  (3.3v rail)
For both configurations the JTAG debugger is connected to the mini USB receptacle labeled J3 on the LPCXpresso LPC1769 board.
PC configuration
Use a PC running Windows XP, Vista or 7 Connect the type-A end of the USB cable that is connected to the board into one of the USB receptacles on the PC
Open a Windows File Explorer window
Build and debug the example
LPCXpresso IDE
In the project explorer window of the IDE right click on the Example_MassStorageDevice project and select Debug As->C/C++ MCU Application
In the main window of the IDE click Run->Resume to start running the application
Keil uVision 4 IDE
In the Batch Build window, select the project targets as described in Compiler Build Configurations and then click Build
In the main window of the IDE click Debug->Start/Stop Debug Session click Debug->Run
How this example runs and what to look for
When the example is run and the board is connected to a PC with a USB cable it will enumerate on the PC as a mass storage device and show up in your Windows file explorer as a drive with the volume label "nxpUSBlib".
The drive will contain a single file called "README.TXT" which contains the text "This is a USB Memory Device demonstration. "
Design notes
This Mass Storage Device example defines a virtual drive size and a physical drive size.
These numbers are defined in the file DataRam.h and look like this:
#define DATA_RAM_START_ADDRESS          0x20080000
#define DATA_RAM_PHYSICAL_SIZE            0xc00
%3CLINGO-SUB%20id%3D%22lingo-sub-1109397%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%A4%A7%E5%AE%B9%E9%87%8F%E5%AD%98%E5%82%A8%E8%AE%BE%E5%A4%87%E7%A4%BA%E4%BE%8B%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1109397%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CH1%20style%3D%22font-size%3A%2026px%3B%20font-weight%3A%20400%3B%20color%3A%20%23333333%3B%20font-family%3A%20Lato%2C%20sans-serif%3B%22%20id%3D%22toc-hId-380756263%22%20id%3D%22toc-hId-1303176791%22%3E%3CSPAN%20style%3D%22font-family%3A%20helvetica%3B%20font-size%3A%2012pt%3B%22%3E%3CSTRONG%3E%3CBIG%3E%E6%8F%8F%E8%BF%B0%3C%2FBIG%3E%3C%2FSTRONG%3E%3C%2FSPAN%3E%3C%2FH1%3E%3CP%20style%3D%22color%3A%20%23646464%3B%20font-family%3A%20Arial%2C%20sans-serif%3B%20font-size%3A%2012px%3B%22%3E%3CSPAN%20style%3D%22font-family%3A%20helvetica%3B%20font-size%3A%2012pt%3B%22%3E%E6%AD%A4%E7%A4%BA%E4%BE%8B%E5%AE%9E%E7%8E%B0%E4%BA%86%E5%AF%B9%E5%AD%98%E5%82%A8%E5%9C%A8%E5%86%85%E9%83%A8%20RAM%20%E4%B8%AD%E7%9A%84%20FAT12%20%E5%8D%B7%E8%BF%9B%E8%A1%8C%E6%93%8D%E4%BD%9C%E7%9A%84%E5%A4%A7%E5%AE%B9%E9%87%8F%E5%AD%98%E5%82%A8%E7%B1%BB%E8%AE%BE%E5%A4%87%E3%80%82%E8%AF%A5%E5%8D%B7%E7%9A%84%E5%A4%A7%E5%B0%8F%E7%94%B1%20DataRam.h%20%E4%B8%AD%E5%AE%9A%E4%B9%89%E7%9A%84%E5%B8%B8%E9%87%8F%20DATA_RAM_PHYSICAL_SIZE%20%E8%AE%BE%E7%BD%AE%3C%2FSPAN%3E%3C%2FP%3E%3CH1%20style%3D%22font-size%3A%2026px%3B%20font-weight%3A%20400%3B%20color%3A%20%23333333%3B%20font-family%3A%20Lato%2C%20sans-serif%3B%22%20id%3D%22toc-hId--1426698200%22%20id%3D%22toc-hId--504277672%22%3E%3CSPAN%20style%3D%22font-family%3A%20helvetica%3B%20font-size%3A%2012pt%3B%22%3E%20%3C%2FSPAN%3E%3C%2FH1%3E%3CH1%20style%3D%22font-size%3A%2026px%3B%20font-weight%3A%20400%3B%20color%3A%20%23333333%3B%20font-family%3A%20Lato%2C%20sans-serif%3B%22%20id%3D%22toc-hId-1060814633%22%20id%3D%22toc-hId-1983235161%22%3E%3CSPAN%20style%3D%22font-family%3A%20helvetica%3B%20font-size%3A%2012pt%3B%22%3E%3CBIG%3E%3CSTRONG%3E%E7%BC%96%E8%AF%91%E5%99%A8%E6%9E%84%E5%BB%BA%E9%85%8D%E7%BD%AE%3C%2FSTRONG%3E%3C%2FBIG%3E%3C%2FSPAN%3E%3C%2FH1%3E%3CP%20style%3D%22color%3A%20%23646464%3B%20font-family%3A%20Arial%2C%20sans-serif%3B%20font-size%3A%2012px%3B%22%3E%3CSPAN%20style%3D%22font-family%3A%20helvetica%3B%20font-size%3A%2012pt%3B%22%3E%E6%9E%84%E6%88%90%E6%AD%A4%E7%A4%BA%E4%BE%8B%E7%9A%84%E8%BD%AF%E4%BB%B6%E8%AE%BE%E8%AE%A1%E7%94%A8%E4%BA%8E%E5%9C%A8%E8%AE%B8%E5%A4%9A%E4%B8%8D%E5%90%8C%E7%9A%84%E5%BC%80%E5%8F%91%E6%9D%BF%E4%B8%8A%E8%BF%90%E8%A1%8C%E3%80%82%E5%9B%A0%E6%AD%A4%EF%BC%8C%E5%BF%85%E9%A1%BB%E9%85%8D%E7%BD%AE%E7%BC%96%E8%AF%91%E5%99%A8%E6%9D%A5%E6%9E%84%E5%BB%BA%E9%92%88%E5%AF%B9%E6%82%A8%E6%AD%A3%E5%9C%A8%E4%BD%BF%E7%94%A8%E7%9A%84%E5%BC%80%E5%8F%91%E6%9D%BF%E7%9A%84%E5%9B%BE%E5%83%8F%E3%80%82%E6%9C%AC%E8%8A%82%E4%BB%8B%E7%BB%8D%E5%A6%82%E4%BD%95%E4%B8%BA%E6%AF%8F%E4%B8%AA%E6%94%AF%E6%8C%81%E7%9A%84%E7%BC%96%E8%AF%91%E5%99%A8%E8%AE%BE%E7%BD%AE%E8%BF%99%E4%BA%9B%E6%9E%84%E5%BB%BA%E9%85%8D%E7%BD%AE%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22min-height%3A%208pt%3B%20padding%3A%200px%3B%22%3E%3CSPAN%20style%3D%22color%3A%20%23646464%3B%20font-family%3A%20helvetica%3B%20font-size%3A%2012pt%3B%22%3E%20%3C%2FSPAN%3E%26nbsp%3B%3C%2FP%3E%3CH2%20style%3D%22font-family%3A%20Lato%2C%20sans-serif%3B%20color%3A%20%23e66e08%3B%20font-size%3A%2018px%3B%20background%3A%200%2050%25%20%23ffffff%3B%22%20id%3D%22toc-hId-1751376107%22%20id%3D%22toc-hId--1621170661%22%3E%3CSPAN%20style%3D%22text-decoration%3A%20underline%3B%20font-family%3A%20helvetica%3B%20font-size%3A%2012pt%3B%22%3ELPCXpresso%20IDE%3C%2FSPAN%3E%3C%2FH2%3E%3CP%20style%3D%22color%3A%20%23646464%3B%20font-family%3A%20Arial%2C%20sans-serif%3B%20font-size%3A%2012px%3B%22%3E%3CSPAN%20style%3D%22font-family%3A%20helvetica%3B%20font-size%3A%2012pt%3B%22%3E%20%3CSTRONG%3E%E9%85%8D%E7%BD%AE%E9%A1%B9%E7%9B%AE%3C%2FSTRONG%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22color%3A%20%23646464%3B%20font-family%3A%20Arial%2C%20sans-serif%3B%20font-size%3A%2012px%3B%22%3E%3CSPAN%20style%3D%22font-family%3A%20helvetica%3B%20font-size%3A%2012pt%3B%22%3E%E5%9C%A8%E9%A1%B9%E7%9B%AE%E8%B5%84%E6%BA%90%E7%AE%A1%E7%90%86%E5%99%A8%E7%AA%97%E5%8F%A3%E4%B8%AD%E5%8F%B3%E9%94%AE%E5%8D%95%E5%87%BB%20BSP%20%E9%A1%B9%E7%9B%AE%3C%2FSPAN%3E%3CBR%20%2F%3E%3CSPAN%20style%3D%22font-family%3A%20helvetica%3B%20font-size%3A%2012pt%3B%22%3E%E7%82%B9%E5%87%BBBuild%20Configurations-%26gt%3BSet%20Active-%26gt%3B%EF%BC%88%E8%A7%81%E4%B8%8B%E8%A1%A8%E4%B8%AD%E7%9A%84%E9%85%8D%E7%BD%AE%EF%BC%89%3C%2FSPAN%3E%3CBR%20%2F%3E%3CSPAN%20style%3D%22font-family%3A%20helvetica%3B%20font-size%3A%2012pt%3B%22%3E%E4%BD%BF%E7%94%A8%20CDL%E3%80%81nxpUSBlib%20%E5%92%8C%20Example_MassStorageDevice%20%E9%87%8D%E5%A4%8D%E8%BF%99%E4%BA%9B%E6%AD%A5%E9%AA%A4%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22color%3A%20%23646464%3B%20font-family%3A%20Arial%2C%20sans-serif%3B%20font-size%3A%2012px%3B%22%3E%3CSPAN%20style%3D%22font-family%3A%20helvetica%3B%20font-size%3A%2012pt%3B%22%3E%20%3CSTRONG%3E%E9%85%8D%E7%BD%AE%20MCU%3C%2FSTRONG%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22color%3A%20%23646464%3B%20font-family%3A%20Arial%2C%20sans-serif%3B%20font-size%3A%2012px%3B%22%3E%3CSPAN%20style%3D%22font-family%3A%20helvetica%3B%20font-size%3A%2012pt%3B%22%3E%E5%9C%A8%E9%A1%B9%E7%9B%AE%E8%B5%84%E6%BA%90%E7%AE%A1%E7%90%86%E5%99%A8%E7%AA%97%E5%8F%A3%E4%B8%AD%E5%8F%B3%E9%94%AE%E5%8D%95%E5%87%BB%20Example_MassStorageDevice%20%E9%A1%B9%E7%9B%AE%3C%2FSPAN%3E%3CBR%20%2F%3E%3CSPAN%20style%3D%22font-family%3A%20helvetica%3B%20font-size%3A%2012pt%3B%22%3E%E7%82%B9%E5%87%BB%E5%B1%9E%E6%80%A7-%26gt%3BC%2FC%2B%2B%20Build-%26gt%3BMCU%E8%AE%BE%E7%BD%AE-%26gt%3B%EF%BC%88%E8%A7%81%E4%B8%8B%E8%A1%A8%E9%85%8D%E7%BD%AE%EF%BC%89%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22color%3A%20%23646464%3B%20font-family%3A%20Arial%2C%20sans-serif%3B%20font-size%3A%2012px%3B%22%3E%3CSPAN%20style%3D%22font-family%3A%20helvetica%3B%20font-size%3A%2012pt%3B%22%3E%20%3CSTRONG%3E%E9%85%8D%E7%BD%AE%E7%B4%A2%E5%BC%95%E5%99%A8%3C%2FSTRONG%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22color%3A%20%23646464%3B%20font-family%3A%20Arial%2C%20sans-serif%3B%20font-size%3A%2012px%3B%22%3E%3CSPAN%20style%3D%22font-family%3A%20helvetica%3B%20font-size%3A%2012pt%3B%22%3E%E5%8D%95%E5%87%BB%E7%AA%97%E5%8F%A3-%26gt%3B%E9%A6%96%E9%80%89%E9%A1%B9-%26gt%3BC%2FC%2B%2B-%26gt%3B%E7%B4%A2%E5%BC%95%E5%99%A8-%26gt%3B%E4%BD%BF%E7%94%A8%E6%B4%BB%E5%8A%A8%E6%9E%84%E5%BB%BA%E9%85%8D%E7%BD%AE%3C%2FSPAN%3E%3C%2FP%3E%3CDIV%20class%3D%22j-rte-table%22%3E%3CTABLE%20border%3D%221%22%20cellpadding%3D%222%22%20cellspacing%3D%228%22%20style%3D%22border-width%3A%200px%3B%20color%3A%20%23646464%3B%20font-family%3A%20Arial%2C%20sans-serif%3B%20font-size%3A%2012px%3B%22%3E%3CTBODY%20style%3D%22border-top-color%3A%20%23cccccc%3B%22%3E%3CTR%20style%3D%22border-width%3A%200px%3B%22%3E%3CTD%20style%3D%22border%3A1px%20solid%20black%3Bborder-width%3A%200px%3Bborder-width%3A%200px%3Bbackground-color%3A%20%23ffcc99%3Btext-align%3A%20center%3Bfont-size%3A%2012px%3Bborder%3A%201px%20solid%20%23000000%3B%22%20valign%3D%22middle%22%3E%3CSPAN%20style%3D%22font-family%3A%20helvetica%3B%20font-size%3A%2012pt%3B%22%3E%20%3C%2FSPAN%3E%3C%2FTD%3E%3CTD%20style%3D%22border%3A1px%20solid%20black%3Bborder-width%3A%200px%3Bborder-width%3A%200px%3Bbackground-color%3A%20%23ffcc99%3Btext-align%3A%20center%3Bfont-size%3A%2012px%3Bborder%3A%201px%20solid%20%23000000%3B%22%20valign%3D%22middle%22%3E%3CP%3E%3CSPAN%20style%3D%22font-family%3A%20helvetica%3B%20font-size%3A%2012pt%3B%22%3EBSP%3C%2FSPAN%3E%3C%2FP%3E%3C%2FTD%3E%3CTD%20style%3D%22border%3A1px%20solid%20black%3Bborder-width%3A%200px%3Bborder-width%3A%200px%3Bbackground-color%3A%20%23ffcc99%3Btext-align%3A%20center%3Bfont-size%3A%2012px%3Bborder%3A%201px%20solid%20%23000000%3B%22%20valign%3D%22middle%22%3E%3CP%3E%3CSPAN%20style%3D%22font-family%3A%20helvetica%3B%20font-size%3A%2012pt%3B%22%3ECDL%3C%2FSPAN%3E%3C%2FP%3E%3C%2FTD%3E%3CTD%20style%3D%22border%3A1px%20solid%20black%3Bborder-width%3A%200px%3Bborder-width%3A%200px%3Bbackground-color%3A%20%23ffcc99%3Btext-align%3A%20center%3Bfont-size%3A%2012px%3Bborder%3A%201px%20solid%20%23000000%3B%22%20valign%3D%22middle%22%3E%3CP%3E%3CSPAN%20style%3D%22font-family%3A%20helvetica%3B%20font-size%3A%2012pt%3B%22%3EnxpUSBlib%3C%2FSPAN%3E%3C%2FP%3E%3C%2FTD%3E%3CTD%20style%3D%22border%3A1px%20solid%20black%3Bborder-width%3A%200px%3Bborder-width%3A%200px%3Bbackground-color%3A%20%23ffcc99%3Btext-align%3A%20center%3Bfont-size%3A%2012px%3Bborder%3A%201px%20solid%20%23000000%3B%22%3E%3CP%3E%3CSPAN%20style%3D%22font-family%3A%20helvetica%3B%20font-size%3A%2012pt%3B%22%3E%E7%A4%BA%E4%BE%8B_%E5%A4%A7%E5%AE%B9%E9%87%8F%E5%AD%98%E5%82%A8%E8%AE%BE%E5%A4%87%3C%2FSPAN%3E%3C%2FP%3E%3C%2FTD%3E%3CTD%20style%3D%22border%3A1px%20solid%20black%3Bborder-width%3A%200px%3Bborder-width%3A%200px%3Bbackground-color%3A%20%23ffcc99%3Btext-align%3A%20center%3Bfont-size%3A%2012px%3Bborder%3A%201px%20solid%20%23000000%3B%22%20valign%3D%22middle%22%3E%3CP%3E%3CSPAN%20style%3D%22font-family%3A%20helvetica%3B%20font-size%3A%2012pt%3B%22%3EMCU%3C%2FSPAN%3E%3C%2FP%3E%3C%2FTD%3E%3C%2FTR%3E%3CTR%20style%3D%22border-width%3A%200px%3B%22%3E%3CTD%20style%3D%22border%3A1px%20solid%20black%3Bborder-width%3A%200px%3Bborder-width%3A%200px%3Bbackground-color%3A%20%23ffcc99%3Btext-align%3A%20center%3Bfont-size%3A%2012px%3Bborder%3A%201px%20solid%20%23000000%3B%22%20valign%3D%22middle%22%3E%3CP%3E%3CSPAN%20style%3D%22font-family%3A%20helvetica%3B%20font-size%3A%2012pt%3B%22%3ELPC1850%26nbsp%3B%20%2F%20Hitex%3C%2FSPAN%3E%3C%2FP%3E%3C%2FTD%3E%3CTD%20style%3D%22border%3A1px%20solid%20black%3Bborder-width%3A%200px%3Bborder-width%3A%200px%3Btext-align%3A%20center%3Bfont-size%3A%2012px%3Bborder%3A%201px%20solid%20%23000000%3B%22%20valign%3D%22middle%22%3E%3CP%3E%3CSPAN%20style%3D%22font-family%3A%20helvetica%3B%20font-size%3A%2012pt%3B%22%3ELPC18xx_HITEX%3C%2FSPAN%3E%3C%2FP%3E%3C%2FTD%3E%3CTD%20style%3D%22border%3A1px%20solid%20black%3Bborder-width%3A%200px%3Bborder-width%3A%200px%3Btext-align%3A%20center%3Bfont-size%3A%2012px%3Bborder%3A%201px%20solid%20%23000000%3B%22%20valign%3D%22middle%22%3E%3CP%3E%3CSPAN%20style%3D%22font-family%3A%20helvetica%3B%20font-size%3A%2012pt%3B%22%3ELPC18xx%3C%2FSPAN%3E%3C%2FP%3E%3C%2FTD%3E%3CTD%20style%3D%22border%3A1px%20solid%20black%3Bborder-width%3A%200px%3Bborder-width%3A%200px%3Btext-align%3A%20center%3Bfont-size%3A%2012px%3Bborder%3A%201px%20solid%20%23000000%3B%22%20valign%3D%22middle%22%3E%3CP%3E%3CSPAN%20style%3D%22font-family%3A%20helvetica%3B%20font-size%3A%2012pt%3B%22%3ELPC18xx_%E8%AE%BE%E5%A4%87%3C%2FSPAN%3E%3C%2FP%3E%3C%2FTD%3E%3CTD%20style%3D%22border%3A1px%20solid%20black%3Bborder-width%3A%200px%3Bborder-width%3A%200px%3Btext-align%3A%20center%3Bfont-size%3A%2012px%3Bborder%3A%201px%20solid%20%23000000%3B%22%20valign%3D%22middle%22%3E%3CP%3E%3CSPAN%20style%3D%22font-family%3A%20helvetica%3B%20font-size%3A%2012pt%3B%22%3ELPC18xx%3C%2FSPAN%3E%3C%2FP%3E%3C%2FTD%3E%3CTD%20style%3D%22border%3A1px%20solid%20black%3Bborder-width%3A%200px%3Bborder-width%3A%200px%3Btext-align%3A%20center%3Bfont-size%3A%2012px%3Bborder%3A%201px%20solid%20%23000000%3B%22%20valign%3D%22middle%22%3E%3CP%3E%3CSPAN%20style%3D%22font-family%3A%20helvetica%3B%20font-size%3A%2012pt%3B%22%3ELPC1850%3C%2FSPAN%3E%3C%2FP%3E%3C%2FTD%3E%3C%2FTR%3E%3CTR%20style%3D%22border-width%3A%200px%3B%22%3E%3CTD%20style%3D%22border%3A1px%20solid%20black%3Bborder-width%3A%200px%3Bborder-width%3A%200px%3Bbackground-color%3A%20%23ffcc99%3Btext-align%3A%20center%3Bfont-size%3A%2012px%3Bborder%3A%201px%20solid%20%23000000%3B%22%20valign%3D%22middle%22%3E%3CP%3E%3CSPAN%20style%3D%22font-family%3A%20helvetica%3B%20font-size%3A%2012pt%3B%22%3ELPC4330%26nbsp%3B%20%2F%20Xplorer%3C%2FSPAN%3E%3C%2FP%3E%3C%2FTD%3E%3CTD%20style%3D%22border%3A1px%20solid%20black%3Bborder-width%3A%200px%3Bborder-width%3A%200px%3Btext-align%3A%20center%3Bfont-size%3A%2012px%3Bborder%3A%201px%20solid%20%23000000%3B%22%20valign%3D%22middle%22%3E%3CP%3E%3CSPAN%20style%3D%22font-family%3A%20helvetica%3B%20font-size%3A%2012pt%3B%22%3ELPC4330_Xplorer%3C%2FSPAN%3E%3C%2FP%3E%3C%2FTD%3E%3CTD%20style%3D%22border%3A1px%20solid%20black%3Bborder-width%3A%200px%3Bborder-width%3A%200px%3Btext-align%3A%20center%3Bfont-size%3A%2012px%3Bborder%3A%201px%20solid%20%23000000%3B%22%20valign%3D%22middle%22%3E%3CP%3E%3CSPAN%20style%3D%22font-family%3A%20helvetica%3B%20font-size%3A%2012pt%3B%22%3ELPC18xx%3C%2FSPAN%3E%3C%2FP%3E%3C%2FTD%3E%3CTD%20style%3D%22border%3A1px%20solid%20black%3Bborder-width%3A%200px%3Bborder-width%3A%200px%3Btext-align%3A%20center%3Bfont-size%3A%2012px%3Bborder%3A%201px%20solid%20%23000000%3B%22%20valign%3D%22middle%22%3E%3CP%3E%3CSPAN%20style%3D%22font-family%3A%20helvetica%3B%20font-size%3A%2012pt%3B%22%3ELPC18xx_%E8%AE%BE%E5%A4%87%3C%2FSPAN%3E%3C%2FP%3E%3C%2FTD%3E%3CTD%20style%3D%22border%3A1px%20solid%20black%3Bborder-width%3A%200px%3Bborder-width%3A%200px%3Btext-align%3A%20center%3Bfont-size%3A%2012px%3Bborder%3A%201px%20solid%20%23000000%3B%22%20valign%3D%22middle%22%3E%3CP%3E%3CSPAN%20style%3D%22font-family%3A%20helvetica%3B%20font-size%3A%2012pt%3B%22%3ELPC18xx%3C%2FSPAN%3E%3C%2FP%3E%3C%2FTD%3E%3CTD%20style%3D%22border%3A1px%20solid%20black%3Bborder-width%3A%200px%3Bborder-width%3A%200px%3Btext-align%3A%20center%3Bfont-size%3A%2012px%3Bborder%3A%201px%20solid%20%23000000%3B%22%20valign%3D%22middle%22%3E%3CP%3E%3CSPAN%20style%3D%22font-family%3A%20helvetica%3B%20font-size%3A%2012pt%3B%22%3ELPC4330%3C%2FSPAN%3E%3C%2FP%3E%3C%2FTD%3E%3C%2FTR%3E%3CTR%20style%3D%22border-width%3A%200px%3B%22%3E%3CTD%20style%3D%22border%3A1px%20solid%20black%3Bborder-width%3A%200px%3Bborder-width%3A%200px%3Bbackground-color%3A%20%23ffcc99%3Btext-align%3A%20center%3Bfont-size%3A%2012px%3Bborder%3A%201px%20solid%20%23000000%3B%22%20valign%3D%22middle%22%3E%3CP%3E%3CSPAN%20style%3D%22font-family%3A%20helvetica%3B%20font-size%3A%2012pt%3B%22%3ELPC4350%26nbsp%3B%20%2F%20Element14%3C%2FSPAN%3E%3C%2FP%3E%3C%2FTD%3E%3CTD%20style%3D%22border%3A1px%20solid%20black%3Bborder-width%3A%200px%3Bborder-width%3A%200px%3Btext-align%3A%20center%3Bfont-size%3A%2012px%3Bborder%3A%201px%20solid%20%23000000%3B%22%20valign%3D%22middle%22%3E%3CP%3E%3CSPAN%20style%3D%22font-family%3A%20helvetica%3B%20font-size%3A%2012pt%3B%22%3ELPC1435_ELEMENT14%3C%2FSPAN%3E%3C%2FP%3E%3C%2FTD%3E%3CTD%20style%3D%22border%3A1px%20solid%20black%3Bborder-width%3A%200px%3Bborder-width%3A%200px%3Btext-align%3A%20center%3Bfont-size%3A%2012px%3Bborder%3A%201px%20solid%20%23000000%3B%22%20valign%3D%22middle%22%3E%3CP%3E%3CSPAN%20style%3D%22font-family%3A%20helvetica%3B%20font-size%3A%2012pt%3B%22%3ELPC18xx%3C%2FSPAN%3E%3C%2FP%3E%3C%2FTD%3E%3CTD%20style%3D%22border%3A1px%20solid%20black%3Bborder-width%3A%200px%3Bborder-width%3A%200px%3Btext-align%3A%20center%3Bfont-size%3A%2012px%3Bborder%3A%201px%20solid%20%23000000%3B%22%20valign%3D%22middle%22%3E%3CP%3E%3CSPAN%20style%3D%22font-family%3A%20helvetica%3B%20font-size%3A%2012pt%3B%22%3ELPC18xx_%E8%AE%BE%E5%A4%87%3C%2FSPAN%3E%3C%2FP%3E%3C%2FTD%3E%3CTD%20style%3D%22border%3A1px%20solid%20black%3Bborder-width%3A%200px%3Bborder-width%3A%200px%3Btext-align%3A%20center%3Bfont-size%3A%2012px%3Bborder%3A%201px%20solid%20%23000000%3B%22%3E%3CP%3E%3CSPAN%20style%3D%22font-family%3A%20helvetica%3B%20font-size%3A%2012pt%3B%22%3ELPC18xx%3C%2FSPAN%3E%3C%2FP%3E%3C%2FTD%3E%3CTD%20style%3D%22border%3A1px%20solid%20black%3Bborder-width%3A%200px%3Bborder-width%3A%200px%3Btext-align%3A%20center%3Bfont-size%3A%2012px%3Bborder%3A%201px%20solid%20%23000000%3B%22%20valign%3D%22middle%22%3E%3CP%3E%3CSPAN%20style%3D%22font-family%3A%20helvetica%3B%20font-size%3A%2012pt%3B%22%3ELPC4350%3C%2FSPAN%3E%3C%2FP%3E%3C%2FTD%3E%3C%2FTR%3E%3CTR%20style%3D%22border-width%3A%200px%3B%22%3E%3CTD%20style%3D%22border%3A1px%20solid%20black%3Bborder-width%3A%200px%3Bborder-width%3A%200px%3Bbackground-color%3A%20%23ffcc99%3Btext-align%3A%20center%3Bfont-size%3A%2012px%3Bborder%3A%201px%20solid%20%23000000%3B%22%20valign%3D%22middle%22%3E%3CP%3E%3CSPAN%20style%3D%22font-family%3A%20helvetica%3B%20font-size%3A%2012pt%3B%22%3ELPC11U14%20%2F%20LPCXpresso%3C%2FSPAN%3E%3C%2FP%3E%3C%2FTD%3E%3CTD%20style%3D%22border%3A1px%20solid%20black%3Bborder-width%3A%200px%3Bborder-width%3A%200px%3Btext-align%3A%20center%3Bfont-size%3A%2012px%3Bborder%3A%201px%20solid%20%23000000%3B%22%20valign%3D%22middle%22%3E%3CP%3E%3CSPAN%20style%3D%22font-family%3A%20helvetica%3B%20font-size%3A%2012pt%3B%22%3ELPC11Uxx_LPCXpressoRevB%3C%2FSPAN%3E%3C%2FP%3E%3C%2FTD%3E%3CTD%20style%3D%22border%3A1px%20solid%20black%3Bborder-width%3A%200px%3Bborder-width%3A%200px%3Btext-align%3A%20center%3Bfont-size%3A%2012px%3Bborder%3A%201px%20solid%20%23000000%3B%22%20valign%3D%22middle%22%3E%3CP%3E%3CSPAN%20style%3D%22font-family%3A%20helvetica%3B%20font-size%3A%2012pt%3B%22%3ELPC11Uxx%3C%2FSPAN%3E%3C%2FP%3E%3C%2FTD%3E%3CTD%20style%3D%22border%3A1px%20solid%20black%3Bborder-width%3A%200px%3Bborder-width%3A%200px%3Btext-align%3A%20center%3Bfont-size%3A%2012px%3Bborder%3A%201px%20solid%20%23000000%3B%22%20valign%3D%22middle%22%3E%3CP%3E%3CSPAN%20style%3D%22font-family%3A%20helvetica%3B%20font-size%3A%2012pt%3B%22%3ELPC11Uxx_%E8%AE%BE%E5%A4%87%3C%2FSPAN%3E%3C%2FP%3E%3C%2FTD%3E%3CTD%20style%3D%22border%3A1px%20solid%20black%3Bborder-width%3A%200px%3Bborder-width%3A%200px%3Btext-align%3A%20center%3Bfont-size%3A%2012px%3Bborder%3A%201px%20solid%20%23000000%3B%22%3E%3CP%3E%3CSPAN%20style%3D%22font-family%3A%20helvetica%3B%20font-size%3A%2012pt%3B%22%3ELPC11Uxx%3C%2FSPAN%3E%3C%2FP%3E%3C%2FTD%3E%3CTD%20style%3D%22border%3A1px%20solid%20black%3Bborder-width%3A%200px%3Bborder-width%3A%200px%3Btext-align%3A%20center%3Bfont-size%3A%2012px%3Bborder%3A%201px%20solid%20%23000000%3B%22%20valign%3D%22middle%22%3E%3CP%3E%3CSPAN%20style%3D%22font-family%3A%20helvetica%3B%20font-size%3A%2012pt%3B%22%3ELPC11U14%3C%2FSPAN%3E%3C%2FP%3E%3C%2FTD%3E%3C%2FTR%3E%3CTR%20style%3D%22border-width%3A%200px%3B%22%3E%3CTD%20style%3D%22border%3A1px%20solid%20black%3Bborder-width%3A%200px%3Bborder-width%3A%200px%3Bbackground-color%3A%20%23ffcc99%3Btext-align%3A%20center%3Bfont-size%3A%2012px%3Bborder%3A%201px%20solid%20%23000000%3B%22%20valign%3D%22middle%22%3E%3CP%3E%3CSPAN%20style%3D%22font-family%3A%20helvetica%3B%20font-size%3A%2012pt%3B%22%3ELPC11U14%20%2F%20MCB1000%3C%2FSPAN%3E%3C%2FP%3E%3C%2FTD%3E%3CTD%20style%3D%22border%3A1px%20solid%20black%3Bborder-width%3A%200px%3Bborder-width%3A%200px%3Btext-align%3A%20center%3Bfont-size%3A%2012px%3Bborder%3A%201px%20solid%20%23000000%3B%22%20valign%3D%22middle%22%3E%3CP%3E%3CSPAN%20style%3D%22font-family%3A%20helvetica%3B%20font-size%3A%2012pt%3B%22%3ELPC11u14_MCB1000%3C%2FSPAN%3E%3C%2FP%3E%3C%2FTD%3E%3CTD%20style%3D%22border%3A1px%20solid%20black%3Bborder-width%3A%200px%3Bborder-width%3A%200px%3Btext-align%3A%20center%3Bfont-size%3A%2012px%3Bborder%3A%201px%20solid%20%23000000%3B%22%20valign%3D%22middle%22%3E%3CP%3E%3CSPAN%20style%3D%22font-family%3A%20helvetica%3B%20font-size%3A%2012pt%3B%22%3ELPC11Uxx%3C%2FSPAN%3E%3C%2FP%3E%3C%2FTD%3E%3CTD%20style%3D%22border%3A1px%20solid%20black%3Bborder-width%3A%200px%3Bborder-width%3A%200px%3Btext-align%3A%20center%3Bfont-size%3A%2012px%3Bborder%3A%201px%20solid%20%23000000%3B%22%20valign%3D%22middle%22%3E%3CP%3E%3CSPAN%20style%3D%22font-family%3A%20helvetica%3B%20font-size%3A%2012pt%3B%22%3ELPC11Uxx_%E8%AE%BE%E5%A4%87%3C%2FSPAN%3E%3C%2FP%3E%3C%2FTD%3E%3CTD%20style%3D%22border%3A1px%20solid%20black%3Bborder-width%3A%200px%3Bborder-width%3A%200px%3Btext-align%3A%20center%3Bfont-size%3A%2012px%3Bborder%3A%201px%20solid%20%23000000%3B%22%3E%3CP%3E%3CSPAN%20style%3D%22font-family%3A%20helvetica%3B%20font-size%3A%2012pt%3B%22%3ELPC11Uxx%3C%2FSPAN%3E%3C%2FP%3E%3C%2FTD%3E%3CTD%20style%3D%22border%3A1px%20solid%20black%3Bborder-width%3A%200px%3Bborder-width%3A%200px%3Btext-align%3A%20center%3Bfont-size%3A%2012px%3Bborder%3A%201px%20solid%20%23000000%3B%22%20valign%3D%22middle%22%3E%3CP%3E%3CSPAN%20style%3D%22font-family%3A%20helvetica%3B%20font-size%3A%2012pt%3B%22%3ELPC11U14%3C%2FSPAN%3E%3C%2FP%3E%3C%2FTD%3E%3C%2FTR%3E%3CTR%20style%3D%22border-width%3A%200px%3B%22%3E%3CTD%20style%3D%22border%3A1px%20solid%20black%3Bborder-width%3A%200px%3Bborder-width%3A%200px%3Bbackground-color%3A%20%23ffcc99%3Btext-align%3A%20center%3Bfont-size%3A%2012px%3Bborder%3A%201px%20solid%20%23000000%3B%22%20valign%3D%22middle%22%3E%3CP%3E%3CSPAN%20style%3D%22font-family%3A%20helvetica%3B%20font-size%3A%2012pt%3B%22%3ELPC1768%2FMCB1700%3C%2FSPAN%3E%3C%2FP%3E%3C%2FTD%3E%3CTD%20style%3D%22border%3A1px%20solid%20black%3Bborder-width%3A%200px%3Bborder-width%3A%200px%3Btext-align%3A%20center%3Bfont-size%3A%2012px%3Bborder%3A%201px%20solid%20%23000000%3B%22%20valign%3D%22middle%22%3E%3CP%3E%3CSPAN%20style%3D%22font-family%3A%20helvetica%3B%20font-size%3A%2012pt%3B%22%3ELPC1768_MCB1700%3C%2FSPAN%3E%3C%2FP%3E%3C%2FTD%3E%3CTD%20style%3D%22border%3A1px%20solid%20black%3Bborder-width%3A%200px%3Bborder-width%3A%200px%3Btext-align%3A%20center%3Bfont-size%3A%2012px%3Bborder%3A%201px%20solid%20%23000000%3B%22%20valign%3D%22middle%22%3E%3CP%3E%3CSPAN%20style%3D%22font-family%3A%20helvetica%3B%20font-size%3A%2012pt%3B%22%3ELPC17xx%3C%2FSPAN%3E%3C%2FP%3E%3C%2FTD%3E%3CTD%20style%3D%22border%3A1px%20solid%20black%3Bborder-width%3A%200px%3Bborder-width%3A%200px%3Btext-align%3A%20center%3Bfont-size%3A%2012px%3Bborder%3A%201px%20solid%20%23000000%3B%22%20valign%3D%22middle%22%3E%3CP%3E%3CSPAN%20style%3D%22font-family%3A%20helvetica%3B%20font-size%3A%2012pt%3B%22%3ELPC17xx_%E8%AE%BE%E5%A4%87%3C%2FSPAN%3E%3C%2FP%3E%3C%2FTD%3E%3CTD%20style%3D%22border%3A1px%20solid%20black%3Bborder-width%3A%200px%3Bborder-width%3A%200px%3Btext-align%3A%20center%3Bfont-size%3A%2012px%3Bborder%3A%201px%20solid%20%23000000%3B%22%3E%3CP%3E%3CSPAN%20style%3D%22font-family%3A%20helvetica%3B%20font-size%3A%2012pt%3B%22%3ELPC17xx%3C%2FSPAN%3E%3C%2FP%3E%3C%2FTD%3E%3CTD%20style%3D%22border%3A1px%20solid%20black%3Bborder-width%3A%200px%3Bborder-width%3A%200px%3Btext-align%3A%20center%3Bfont-size%3A%2012px%3Bborder%3A%201px%20solid%20%23000000%3B%22%20valign%3D%22middle%22%3E%3CP%3E%3CSPAN%20style%3D%22font-family%3A%20helvetica%3B%20font-size%3A%2012pt%3B%22%3ELPC1768%3C%2FSPAN%3E%3C%2FP%3E%3C%2FTD%3E%3C%2FTR%3E%3CTR%20style%3D%22border-width%3A%200px%3B%22%3E%3CTD%20style%3D%22border%3A1px%20solid%20black%3Bborder-width%3A%200px%3Bborder-width%3A%200px%3Bbackground-color%3A%20%23ffcc99%3Btext-align%3A%20center%3Bfont-size%3A%2012px%3Bborder%3A%201px%20solid%20%23000000%3B%22%20valign%3D%22middle%22%3E%3CP%3E%3CSPAN%20style%3D%22font-family%3A%20helvetica%3B%20font-size%3A%2012pt%3B%22%3ELPC1768%26nbsp%3B%20%2F%20LPCXpresso%3C%2FSPAN%3E%3C%2FP%3E%3C%2FTD%3E%3CTD%20style%3D%22border%3A1px%20solid%20black%3Bborder-width%3A%200px%3Bborder-width%3A%200px%3Btext-align%3A%20center%3Bfont-size%3A%2012px%3Bborder%3A%201px%20solid%20%23000000%3B%22%20valign%3D%22middle%22%3E%3CP%3E%3CSPAN%20style%3D%22font-family%3A%20helvetica%3B%20font-size%3A%2012pt%3B%22%3ELPC17xx_LPCXpressoRevB%3C%2FSPAN%3E%3C%2FP%3E%3C%2FTD%3E%3CTD%20style%3D%22border%3A1px%20solid%20black%3Bborder-width%3A%200px%3Bborder-width%3A%200px%3Btext-align%3A%20center%3Bfont-size%3A%2012px%3Bborder%3A%201px%20solid%20%23000000%3B%22%20valign%3D%22middle%22%3E%3CP%3E%3CSPAN%20style%3D%22font-family%3A%20helvetica%3B%20font-size%3A%2012pt%3B%22%3ELPC17xx%3C%2FSPAN%3E%3C%2FP%3E%3C%2FTD%3E%3CTD%20style%3D%22border%3A1px%20solid%20black%3Bborder-width%3A%200px%3Bborder-width%3A%200px%3Btext-align%3A%20center%3Bfont-size%3A%2012px%3Bborder%3A%201px%20solid%20%23000000%3B%22%20valign%3D%22middle%22%3E%3CP%3E%3CSPAN%20style%3D%22font-family%3A%20helvetica%3B%20font-size%3A%2012pt%3B%22%3ELPC17xx_%E8%AE%BE%E5%A4%87%3C%2FSPAN%3E%3C%2FP%3E%3C%2FTD%3E%3CTD%20style%3D%22border%3A1px%20solid%20black%3Bborder-width%3A%200px%3Bborder-width%3A%200px%3Btext-align%3A%20center%3Bfont-size%3A%2012px%3Bborder%3A%201px%20solid%20%23000000%3B%22%20valign%3D%22middle%22%3E%3CP%3E%3CSPAN%20style%3D%22font-family%3A%20helvetica%3B%20font-size%3A%2012pt%3B%22%3ELPC17xx%3C%2FSPAN%3E%3C%2FP%3E%3C%2FTD%3E%3CTD%20style%3D%22border%3A1px%20solid%20black%3Bborder-width%3A%200px%3Bborder-width%3A%200px%3Btext-align%3A%20center%3Bfont-size%3A%2012px%3Bborder%3A%201px%20solid%20%23000000%3B%22%20valign%3D%22middle%22%3E%3CP%3E%3CSPAN%20style%3D%22font-family%3A%20helvetica%3B%20font-size%3A%2012pt%3B%22%3ELPC1768%3C%2FSPAN%3E%3C%2FP%3E%3C%2FTD%3E%3C%2FTR%3E%3CTR%20style%3D%22border-width%3A%200px%3B%22%3E%3CTD%20style%3D%22border%3A1px%20solid%20black%3Bborder-width%3A%200px%3Bborder-width%3A%200px%3Bfont-size%3A%2012px%3Bborder-width%3A%200px%3B%22%3E%3CSPAN%20style%3D%22font-family%3A%20helvetica%3B%20font-size%3A%2012pt%3B%22%3E%20%3C%2FSPAN%3E%3C%2FTD%3E%3CTD%20style%3D%22border%3A1px%20solid%20black%3Bborder-width%3A%200px%3Bborder-width%3A%200px%3Bfont-size%3A%2012px%3Bborder-width%3A%200px%3B%22%3E%3CSPAN%20style%3D%22font-family%3A%20helvetica%3B%20font-size%3A%2012pt%3B%22%3E%20%3C%2FSPAN%3E%3C%2FTD%3E%3CTD%20style%3D%22border%3A1px%20solid%20black%3Bborder-width%3A%200px%3Bborder-width%3A%200px%3Bfont-size%3A%2012px%3Bborder-width%3A%200px%3B%22%3E%3CSPAN%20style%3D%22font-family%3A%20helvetica%3B%20font-size%3A%2012pt%3B%22%3E%20%3C%2FSPAN%3E%3C%2FTD%3E%3CTD%20style%3D%22border%3A1px%20solid%20black%3Bborder-width%3A%200px%3Bborder-width%3A%200px%3Bfont-size%3A%2012px%3Bborder-width%3A%200px%3B%22%3E%3CSPAN%20style%3D%22font-family%3A%20helvetica%3B%20font-size%3A%2012pt%3B%22%3E%20%3C%2FSPAN%3E%3C%2FTD%3E%3CTD%20style%3D%22border%3A1px%20solid%20black%3Bborder-width%3A%200px%3Bborder-width%3A%200px%3Bfont-size%3A%2012px%3Bborder-width%3A%200px%3B%22%3E%3CSPAN%20style%3D%22font-family%3A%20helvetica%3B%20font-size%3A%2012pt%3B%22%3E%20%3C%2FSPAN%3E%3C%2FTD%3E%3CTD%20style%3D%22border%3A1px%20solid%20black%3Bborder-width%3A%200px%3Bborder-width%3A%200px%3Bfont-size%3A%2012px%3Bborder-width%3A%200px%3B%22%3E%3CSPAN%20style%3D%22font-family%3A%20helvetica%3B%20font-size%3A%2012pt%3B%22%3E%20%3C%2FSPAN%3E%3C%2FTD%3E%3C%2FTR%3E%3C%2FTBODY%3E%3C%2FTABLE%3E%3C%2FDIV%3E%3CP%20style%3D%22color%3A%20%23646464%3B%20font-family%3A%20Arial%2C%20sans-serif%3B%20font-size%3A%2012px%3B%22%3E%3CSPAN%20style%3D%22font-family%3A%20helvetica%3B%20font-size%3A%2012pt%3B%22%3E%3CSPAN%20style%3D%22font-weight%3A%20bold%3B%22%3E%3CBR%20%2F%3E%E6%B3%A8%E6%84%8F%EF%BC%9A%3C%2FSPAN%3E%20LPC18xx%20CDL%20%E4%B8%8E%E8%A3%85%E6%9C%89%20LPC43xx%20%E9%83%A8%E4%BB%B6%E7%9A%84%E7%94%B5%E8%B7%AF%E6%9D%BF%E4%B8%80%E8%B5%B7%E4%BD%BF%E7%94%A8%E3%80%82%E8%BF%99%E6%A0%B7%E5%81%9A%E6%98%AF%E5%9B%A0%E4%B8%BA%20LPC43xx%20CDL%20%E7%9B%AE%E5%89%8D%E5%A4%84%E4%BA%8E%E5%AE%9E%E9%AA%8C%E9%98%B6%E6%AE%B5%E3%80%82%E4%BD%BF%E7%94%A8%20LPC18xx%20USB%20%E5%BA%93%E6%98%AF%E5%9B%A0%E4%B8%BA%E4%B8%A4%E4%B8%AA%E9%83%A8%E5%88%86%E5%85%B1%E4%BA%AB%E7%9B%B8%E5%90%8C%E7%9A%84%E6%8E%A7%E5%88%B6%E5%99%A8%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22min-height%3A%208pt%3B%20padding%3A%200px%3B%20color%3A%20%23646464%3B%20font-family%3A%20Arial%2C%20sans-serif%3B%20font-size%3A%2012px%3B%22%3E%3CSPAN%20style%3D%22font-family%3A%20helvetica%3B%20font-size%3A%2012pt%3B%22%3E%20%3C%2FSPAN%3E%26nbsp%3B%3C%2FP%3E%3CH2%20style%3D%22font-family%3A%20Lato%2C%20sans-serif%3B%20color%3A%20%23e66e08%3B%20font-size%3A%2018px%3B%20background%3A%200%2050%25%20%23ffffff%3B%22%20id%3D%22toc-hId--56078356%22%20id%3D%22toc-hId-866342172%22%3E%3CSPAN%20style%3D%22text-decoration%3A%20underline%3B%20font-family%3A%20helvetica%3B%20font-size%3A%2012pt%3B%22%3EKeil%20uVision%204%20IDE%3C%2FSPAN%3E%3C%2FH2%3E%3CP%20style%3D%22color%3A%20%23646464%3B%20font-family%3A%20Arial%2C%20sans-serif%3B%20font-size%3A%2012px%3B%22%3E%3CSPAN%20style%3D%22font-family%3A%20helvetica%3B%20font-size%3A%2012pt%3B%22%3E%20%3CSTRONG%3E%E9%85%8D%E7%BD%AE%E6%89%B9%E9%87%8F%E6%9E%84%E5%BB%BA%3C%2FSTRONG%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22min-height%3A%208pt%3B%20padding%3A%200px%3B%22%3E%26nbsp%3B%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-family%3A%20helvetica%3B%20font-size%3A%2012pt%3B%22%3E%E7%82%B9%E5%87%BB%E9%A1%B9%E7%9B%AE-%26gt%3B%E6%89%B9%E9%87%8F%E6%9E%84%E5%BB%BA...%3C%2FSPAN%3E%3CBR%20%2F%3E%3CSPAN%20style%3D%22font-family%3A%20helvetica%3B%20font-size%3A%2012pt%3B%22%3E%E5%B1%95%E5%BC%80%20BSP%20%E9%A1%B9%E7%9B%AE%E4%BB%A5%E6%98%BE%E7%A4%BA%E9%A1%B9%E7%9B%AE%E7%9B%AE%E6%A0%87%E5%88%97%E8%A1%A8%3C%2FSPAN%3E%3CBR%20%2F%3E%3CSPAN%20style%3D%22font-family%3A%20helvetica%3B%20font-size%3A%2012pt%3B%22%3E%E9%80%9A%E8%BF%87%E9%80%89%E4%B8%AD%E7%9B%B8%E5%BA%94%E7%9A%84%E5%A4%8D%E9%80%89%E6%A1%86%E6%9D%A5%E9%80%89%E6%8B%A9%E9%A1%B9%E7%9B%AE%E7%9B%AE%E6%A0%87%EF%BC%88%E8%AF%B7%E5%8F%82%E9%98%85%E4%B8%8B%E8%A1%A8%E4%B8%AD%E7%9A%84%E7%9B%AE%E6%A0%87%E5%88%97%E8%A1%A8%EF%BC%89%3C%2FSPAN%3E%3CBR%20%2F%3E%3CSPAN%20style%3D%22font-family%3A%20helvetica%3B%20font-size%3A%2012pt%3B%22%3E%E4%BD%BF%E7%94%A8%20CDL%E3%80%81nxpUSBlib_Device%20%E5%92%8C%20Example_MassStorageDevice%20%E9%87%8D%E5%A4%8D%E8%BF%99%E4%BA%9B%E6%AD%A5%E9%AA%A4%3C%2FSPAN%3E%3C%2FP%3E%3CDIV%20class%3D%22j-rte-table%22%3E%3CTABLE%20border%3D%221%22%20cellpadding%3D%222%22%20cellspacing%3D%228%22%20style%3D%22border-width%3A%200px%3B%20color%3A%20%23646464%3B%20font-family%3A%20Arial%2C%20sans-serif%3B%20font-size%3A%2012px%3B%22%3E%3CTBODY%20style%3D%22border-top-color%3A%20%23cccccc%3B%22%3E%3CTR%20style%3D%22border-width%3A%200px%3B%22%3E%3CTD%20style%3D%22border%3A1px%20solid%20black%3Bborder-width%3A%200px%3Bborder-width%3A%200px%3Bbackground-color%3A%20%23ffcc99%3Btext-align%3A%20center%3Bfont-size%3A%2012px%3Bborder%3A%201px%20solid%20%23000000%3B%22%3E%3CSPAN%20style%3D%22font-family%3A%20helvetica%3B%20font-size%3A%2012pt%3B%22%3E%20%3C%2FSPAN%3E%3C%2FTD%3E%3CTD%20style%3D%22border%3A1px%20solid%20black%3Bborder-width%3A%200px%3Bborder-width%3A%200px%3Bbackground-color%3A%20%23ffcc99%3Btext-align%3A%20center%3Bfont-size%3A%2012px%3Bborder%3A%201px%20solid%20%23000000%3B%22%3E%3CP%3E%3CSPAN%20style%3D%22font-family%3A%20helvetica%3B%20font-size%3A%2012pt%3B%22%3EBSP%3C%2FSPAN%3E%3C%2FP%3E%3C%2FTD%3E%3CTD%20style%3D%22border%3A1px%20solid%20black%3Bborder-width%3A%200px%3Bborder-width%3A%200px%3Bbackground-color%3A%20%23ffcc99%3Btext-align%3A%20center%3Bfont-size%3A%2012px%3Bborder%3A%201px%20solid%20%23000000%3B%22%3E%3CP%3E%3CSPAN%20style%3D%22font-family%3A%20helvetica%3B%20font-size%3A%2012pt%3B%22%3ECDL%3C%2FSPAN%3E%3C%2FP%3E%3C%2FTD%3E%3CTD%20style%3D%22border%3A1px%20solid%20black%3Bborder-width%3A%200px%3Bborder-width%3A%200px%3Bbackground-color%3A%20%23ffcc99%3Btext-align%3A%20center%3Bfont-size%3A%2012px%3Bborder%3A%201px%20solid%20%23000000%3B%22%3E%3CP%3E%3CSPAN%20style%3D%22font-family%3A%20helvetica%3B%20font-size%3A%2012pt%3B%22%3EnxpUSBlib_%E8%AE%BE%E5%A4%87%3C%2FSPAN%3E%3C%2FP%3E%3C%2FTD%3E%3CTD%20style%3D%22border%3A1px%20solid%20black%3Bborder-width%3A%200px%3Bborder-width%3A%200px%3Bbackground-color%3A%20%23ffcc99%3Btext-align%3A%20center%3Bfont-size%3A%2012px%3Bborder%3A%201px%20solid%20%23000000%3B%22%3E%3CP%3E%3CSPAN%20style%3D%22font-family%3A%20helvetica%3B%20font-size%3A%2012pt%3B%22%3E%E7%A4%BA%E4%BE%8B_%E5%A4%A7%E5%AE%B9%E9%87%8F%E5%AD%98%E5%82%A8%E8%AE%BE%E5%A4%87%3C%2FSPAN%3E%3C%2FP%3E%3C%2FTD%3E%3C%2FTR%3E%3CTR%20style%3D%22border-width%3A%200px%3B%22%3E%3CTD%20style%3D%22border%3A1px%20solid%20black%3Bborder-width%3A%200px%3Bborder-width%3A%200px%3Bbackground-color%3A%20%23ffcc99%3Btext-align%3A%20center%3Bfont-size%3A%2012px%3Bborder%3A%201px%20solid%20%23000000%3B%22%3E%3CP%3E%3CSPAN%20style%3D%22font-family%3A%20helvetica%3B%20font-size%3A%2012pt%3B%22%3ELPC1850%26nbsp%3B%20%2F%20Hitex%3C%2FSPAN%3E%3C%2FP%3E%3C%2FTD%3E%3CTD%20style%3D%22border%3A1px%20solid%20black%3Bborder-width%3A%200px%3Bborder-width%3A%200px%3Btext-align%3A%20center%3Bfont-size%3A%2012px%3Bborder%3A%201px%20solid%20%23000000%3B%22%3E%3CP%3E%3CSPAN%20style%3D%22font-family%3A%20helvetica%3B%20font-size%3A%2012pt%3B%22%3EHITEX1800%3C%2FSPAN%3E%3C%2FP%3E%3C%2FTD%3E%3CTD%20style%3D%22border%3A1px%20solid%20black%3Bborder-width%3A%200px%3Bborder-width%3A%200px%3Btext-align%3A%20center%3Bfont-size%3A%2012px%3Bborder%3A%201px%20solid%20%23000000%3B%22%3E%3CP%3E%3CSPAN%20style%3D%22font-family%3A%20helvetica%3B%20font-size%3A%2012pt%3B%22%3ELPC18xx%3C%2FSPAN%3E%3C%2FP%3E%3C%2FTD%3E%3CTD%20style%3D%22border%3A1px%20solid%20black%3Bborder-width%3A%200px%3Bborder-width%3A%200px%3Btext-align%3A%20center%3Bfont-size%3A%2012px%3Bborder%3A%201px%20solid%20%23000000%3B%22%3E%3CP%3E%3CSPAN%20style%3D%22font-family%3A%20helvetica%3B%20font-size%3A%2012pt%3B%22%3ELPC18xx_%E8%AE%BE%E5%A4%87%3C%2FSPAN%3E%3C%2FP%3E%3C%2FTD%3E%3CTD%20style%3D%22border%3A1px%20solid%20black%3Bborder-width%3A%200px%3Bborder-width%3A%200px%3Btext-align%3A%20center%3Bfont-size%3A%2012px%3Bborder%3A%201px%20solid%20%23000000%3B%22%3E%3CP%3E%3CSPAN%20style%3D%22font-family%3A%20helvetica%3B%20font-size%3A%2012pt%3B%22%3EHITEX1800%3C%2FSPAN%3E%3C%2FP%3E%3C%2FTD%3E%3C%2FTR%3E%3CTR%20style%3D%22border-width%3A%200px%3B%22%3E%3CTD%20style%3D%22border%3A1px%20solid%20black%3Bborder-width%3A%200px%3Bborder-width%3A%200px%3Bbackground-color%3A%20%23ffcc99%3Btext-align%3A%20center%3Bfont-size%3A%2012px%3Bborder%3A%201px%20solid%20%23000000%3B%22%3E%3CP%3E%3CSPAN%20style%3D%22font-family%3A%20helvetica%3B%20font-size%3A%2012pt%3B%22%3ELPC1768%2FMCB1700%3C%2FSPAN%3E%3C%2FP%3E%3C%2FTD%3E%3CTD%20style%3D%22border%3A1px%20solid%20black%3Bborder-width%3A%200px%3Bborder-width%3A%200px%3Btext-align%3A%20center%3Bfont-size%3A%2012px%3Bborder%3A%201px%20solid%20%23000000%3B%22%3E%3CP%3E%3CSPAN%20style%3D%22font-family%3A%20helvetica%3B%20font-size%3A%2012pt%3B%22%3EMCB1700%3C%2FSPAN%3E%3C%2FP%3E%3C%2FTD%3E%3CTD%20style%3D%22border%3A1px%20solid%20black%3Bborder-width%3A%200px%3Bborder-width%3A%200px%3Btext-align%3A%20center%3Bfont-size%3A%2012px%3Bborder%3A%201px%20solid%20%23000000%3B%22%3E%3CP%3E%3CSPAN%20style%3D%22font-family%3A%20helvetica%3B%20font-size%3A%2012pt%3B%22%3ELPC17xx%3C%2FSPAN%3E%3C%2FP%3E%3C%2FTD%3E%3CTD%20style%3D%22border%3A1px%20solid%20black%3Bborder-width%3A%200px%3Bborder-width%3A%200px%3Btext-align%3A%20center%3Bfont-size%3A%2012px%3Bborder%3A%201px%20solid%20%23000000%3B%22%3E%3CP%3E%3CSPAN%20style%3D%22font-family%3A%20helvetica%3B%20font-size%3A%2012pt%3B%22%3ELPC17xx_%E8%AE%BE%E5%A4%87%3C%2FSPAN%3E%3C%2FP%3E%3C%2FTD%3E%3CTD%20style%3D%22border%3A1px%20solid%20black%3Bborder-width%3A%200px%3Bborder-width%3A%200px%3Btext-align%3A%20center%3Bfont-size%3A%2012px%3Bborder%3A%201px%20solid%20%23000000%3B%22%3E%3CP%3E%3CSPAN%20style%3D%22font-family%3A%20helvetica%3B%20font-size%3A%2012pt%3B%22%3EMCB1700%3C%2FSPAN%3E%3C%2FP%3E%3C%2FTD%3E%3C%2FTR%3E%3CTR%20style%3D%22border-width%3A%200px%3B%22%3E%3CTD%20style%3D%22border%3A1px%20solid%20black%3Bborder-width%3A%200px%3Bborder-width%3A%200px%3Bbackground-color%3A%20%23ffcc99%3Btext-align%3A%20center%3Bfont-size%3A%2012px%3Bborder%3A%201px%20solid%20%23000000%3B%22%3E%3CP%3E%3CSPAN%20style%3D%22font-family%3A%20helvetica%3B%20font-size%3A%2012pt%3B%22%3ELPC11U14%20%2F%20MCB1000%3C%2FSPAN%3E%3C%2FP%3E%3C%2FTD%3E%3CTD%20style%3D%22border%3A1px%20solid%20black%3Bborder-width%3A%200px%3Bborder-width%3A%200px%3Btext-align%3A%20center%3Bfont-size%3A%2012px%3Bborder%3A%201px%20solid%20%23000000%3B%22%3E%3CP%3E%3CSPAN%20style%3D%22font-family%3A%20helvetica%3B%20font-size%3A%2012pt%3B%22%3EMCB1000%3C%2FSPAN%3E%3C%2FP%3E%3C%2FTD%3E%3CTD%20style%3D%22border%3A1px%20solid%20black%3Bborder-width%3A%200px%3Bborder-width%3A%200px%3Btext-align%3A%20center%3Bfont-size%3A%2012px%3Bborder%3A%201px%20solid%20%23000000%3B%22%3E%3CP%3E%3CSPAN%20style%3D%22font-family%3A%20helvetica%3B%20font-size%3A%2012pt%3B%22%3ELPC11Uxx%3C%2FSPAN%3E%3C%2FP%3E%3C%2FTD%3E%3CTD%20style%3D%22border%3A1px%20solid%20black%3Bborder-width%3A%200px%3Bborder-width%3A%200px%3Btext-align%3A%20center%3Bfont-size%3A%2012px%3Bborder%3A%201px%20solid%20%23000000%3B%22%3E%3CP%3E%3CSPAN%20style%3D%22font-family%3A%20helvetica%3B%20font-size%3A%2012pt%3B%22%3ELPC11Uxx_%E8%AE%BE%E5%A4%87%3C%2FSPAN%3E%3C%2FP%3E%3C%2FTD%3E%3CTD%20style%3D%22border%3A1px%20solid%20black%3Bborder-width%3A%200px%3Bborder-width%3A%200px%3Btext-align%3A%20center%3Bfont-size%3A%2012px%3Bborder%3A%201px%20solid%20%23000000%3B%22%3E%3CP%3E%3CSPAN%20style%3D%22font-family%3A%20helvetica%3B%20font-size%3A%2012pt%3B%22%3EMCB1000%3C%2FSPAN%3E%3C%2FP%3E%3C%2FTD%3E%3C%2FTR%3E%3C%2FTBODY%3E%3C%2FTABLE%3E%3C%2FDIV%3E%3CP%20style%3D%22min-height%3A%208pt%3B%20padding%3A%200px%3B%22%3E%3CSPAN%20style%3D%22color%3A%20%23646464%3B%20font-family%3A%20helvetica%3B%20font-size%3A%2012pt%3B%22%3E%20%3C%2FSPAN%3E%26nbsp%3B%3C%2FP%3E%3CH1%20style%3D%22font-size%3A%2026px%3B%20font-weight%3A%20400%3B%20color%3A%20%23333333%3B%20font-family%3A%20Lato%2C%20sans-serif%3B%22%20id%3D%22toc-hId--66581460%22%20id%3D%22toc-hId-855839068%22%3E%3CSPAN%20style%3D%22font-family%3A%20helvetica%3B%20font-size%3A%2012pt%3B%22%3E%3CBIG%3E%3CSTRONG%3E%E7%94%B5%E8%B7%AF%E6%9D%BF%E8%BF%9E%E6%8E%A5%E5%92%8C%E9%85%8D%E7%BD%AE%3C%2FSTRONG%3E%3C%2FBIG%3E%3C%2FSPAN%3E%3C%2FH1%3E%3CP%20style%3D%22min-height%3A%208pt%3B%20padding%3A%200px%3B%20color%3A%20%23646464%3B%20font-family%3A%20Arial%2C%20sans-serif%3B%20font-size%3A%2012px%3B%22%3E%3CSPAN%20style%3D%22font-family%3A%20helvetica%3B%20font-size%3A%2012pt%3B%22%3E%20%3C%2FSPAN%3E%26nbsp%3B%3C%2FP%3E%3CH2%20style%3D%22font-family%3A%20Lato%2C%20sans-serif%3B%20color%3A%20%23e66e08%3B%20font-size%3A%2018px%3B%20background%3A%200%2050%25%20%23ffffff%3B%22%20id%3D%22toc-hId-623980014%22%20id%3D%22toc-hId-1546400542%22%3E%3CSPAN%20style%3D%22text-decoration%3A%20underline%3B%20font-family%3A%20helvetica%3B%20font-size%3A%2012pt%3B%22%3ELPC18xx_HITEX%EF%BC%88LPC1850%20Hitex%20%E8%AF%84%E4%BC%B0%E6%9D%BF%EF%BC%89%E6%97%A7%E6%AC%BE%20A2%20%E8%AE%BE%E8%AE%A1%3C%2FSPAN%3E%3C%2FH2%3E%3CP%20style%3D%22color%3A%20%23646464%3B%20font-family%3A%20Arial%2C%20sans-serif%3B%20font-size%3A%2012px%3B%22%3E%3CSPAN%20style%3D%22font-family%3A%20helvetica%3B%20font-size%3A%2012pt%3B%22%3E%3CSPAN%20style%3D%22font-weight%3A%20bold%3B%22%3E%E5%8E%9F%E7%90%86%E5%9B%BE%3C%2FSPAN%3E.%2FBSP%2Fschematics%2FHITEX_SCM_LPC1850EVA-A2-2.pdf%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22min-height%3A%208pt%3B%20padding%3A%200px%3B%22%3E%26nbsp%3B%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-family%3A%20helvetica%3B%20font-size%3A%2012pt%3B%22%3E%E5%B0%86%20JTAG%20%E8%BF%9E%E6%8E%A5%E5%88%B0%E6%A0%87%E6%9C%89%20X4%20JTAG%20%E7%9A%84%2020%20%E9%92%88%E6%8F%92%E5%BA%A7%3C%2FSPAN%3E%3CBR%20%2F%3E%3CSPAN%20style%3D%22font-family%3A%20helvetica%3B%20font-size%3A%2012pt%3B%22%3E%E5%B0%86%20USB%20%E6%95%B0%E6%8D%AE%E7%BA%BF%E7%9A%84%20B%20%E5%9E%8B%E7%AB%AF%E8%BF%9E%E6%8E%A5%E5%88%B0%E6%A0%87%E6%9C%89%20X2%20%E7%9A%84%E6%8F%92%E5%BA%A7%E3%80%82%E5%B0%86%E6%AD%A4%E6%95%B0%E6%8D%AE%E7%BA%BF%E7%9A%84%20A%20%E5%9E%8B%E7%AB%AF%E6%8F%92%E5%85%A5%20PC%3C%2FSPAN%3E%3CBR%20%2F%3E%3CSPAN%20style%3D%22font-family%3A%20helvetica%3B%20font-size%3A%2012pt%3B%22%3E%20%3C%2FSPAN%3E%3C%2FP%3E%3CH2%20style%3D%22font-family%3A%20Lato%2C%20sans-serif%3B%20color%3A%20%23e66e08%3B%20font-size%3A%2018px%3B%20background%3A%200%2050%25%20%23ffffff%3B%22%20id%3D%22toc-hId--1183474449%22%20id%3D%22toc-hId--261053921%22%3E%3CSPAN%20style%3D%22text-decoration%3A%20underline%3B%20font-family%3A%20helvetica%3B%20font-size%3A%2012pt%3B%22%3ELPC18xx_HITEX%EF%BC%88LPC1850%20Hitex%20%E8%AF%84%E4%BC%B0%E6%9D%BF%EF%BC%89%E8%BE%83%E6%96%B0%E7%9A%84%20A4%20%E8%AE%BE%E8%AE%A1%3C%2FSPAN%3E%3C%2FH2%3E%3CP%20style%3D%22color%3A%20%23646464%3B%20font-family%3A%20Arial%2C%20sans-serif%3B%20font-size%3A%2012px%3B%22%3E%3CSPAN%20style%3D%22font-family%3A%20helvetica%3B%20font-size%3A%2012pt%3B%22%3E%20%3CSPAN%20style%3D%22font-weight%3A%20bold%3B%22%3E%E5%8E%9F%E7%90%86%E5%9B%BE%3C%2FSPAN%3E.%2FBSP%2Fschematics%2FHITEX_Final_LPC1850EVA-A3.pdf%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22min-height%3A%208pt%3B%20padding%3A%200px%3B%20color%3A%20%23646464%3B%20font-family%3A%20Arial%2C%20sans-serif%3B%20font-size%3A%2012px%3B%22%3E%3CSPAN%20style%3D%22font-family%3A%20helvetica%3B%20font-size%3A%2012pt%3B%22%3E%20%3C%2FSPAN%3E%26nbsp%3B%3C%2FP%3E%3CH2%20style%3D%22font-family%3A%20Lato%2C%20sans-serif%3B%20color%3A%20%23e66e08%3B%20font-size%3A%2018px%3B%20background%3A%200%2050%25%20%23ffffff%3B%22%20id%3D%22toc-hId-1304038384%22%20id%3D%22toc-hId--2068508384%22%3E%3CSPAN%20style%3D%22text-decoration%3A%20underline%3B%20font-family%3A%20helvetica%3B%20font-size%3A%2012pt%3B%22%3ELPC4330_Xplorer%EF%BC%88%E5%B8%A6%20LPC4330%20%E7%9A%84%20NGX%20Xplorer%20%E8%AF%84%E4%BC%B0%E6%9D%BF%EF%BC%89%3C%2FSPAN%3E%3C%2FH2%3E%3CP%20style%3D%22color%3A%20%23646464%3B%20font-family%3A%20Arial%2C%20sans-serif%3B%20font-size%3A%2012px%3B%22%3E%3CSPAN%20style%3D%22font-family%3A%20helvetica%3B%20font-size%3A%2012pt%3B%22%3E%E5%B0%86%20JTAG%20%E8%BF%9E%E6%8E%A5%E5%88%B0%E6%A0%87%E6%9C%89%20J2%20%E7%9A%84%2010%20%E9%92%88%E6%8F%92%E5%BA%A7%3C%2FSPAN%3E%3CBR%20%2F%3E%3CSPAN%20style%3D%22font-family%3A%20helvetica%3B%20font-size%3A%2012pt%3B%22%3E%E5%B0%86%20USB%20%E6%95%B0%E6%8D%AE%E7%BA%BF%E7%9A%84%20micro-b%20%E7%AB%AF%E8%BF%9E%E6%8E%A5%E5%88%B0%E6%A0%87%E6%9C%89%20USB0%20%E7%9A%84%E6%8F%92%E5%BA%A7%E3%80%82%E5%B0%86%E6%AD%A4%E6%95%B0%E6%8D%AE%E7%BA%BF%E7%9A%84%20type-A%20%E7%AB%AF%E6%8F%92%E5%85%A5%20PC%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22min-height%3A%208pt%3B%20padding%3A%200px%3B%20color%3A%20%23646464%3B%20font-family%3A%20Arial%2C%20sans-serif%3B%20font-size%3A%2012px%3B%22%3E%3CSPAN%20style%3D%22font-family%3A%20helvetica%3B%20font-size%3A%2012pt%3B%22%3E%20%3C%2FSPAN%3E%26nbsp%3B%3C%2FP%3E%3CH2%20style%3D%22font-family%3A%20Lato%2C%20sans-serif%3B%20color%3A%20%23e66e08%3B%20font-size%3A%2018px%3B%20background%3A%200%2050%25%20%23ffffff%3B%22%20id%3D%22toc-hId--503416079%22%20id%3D%22toc-hId-419004449%22%3E%3CSPAN%20style%3D%22text-decoration%3A%20underline%3B%20font-family%3A%20helvetica%3B%20font-size%3A%2012pt%3B%22%3ELPC1435_ELEMENT14%EF%BC%88%E5%B8%A6%20LPC4350%20%E7%9A%84%20Element%2014%20%E6%B8%B8%E6%88%8F%E6%9D%BF%EF%BC%89%3C%2FSPAN%3E%3C%2FH2%3E%3CP%20style%3D%22color%3A%20%23646464%3B%20font-family%3A%20Arial%2C%20sans-serif%3B%20font-size%3A%2012px%3B%22%3E%3CSPAN%20style%3D%22font-family%3A%20helvetica%3B%20font-size%3A%2012pt%3B%22%3E%E5%B0%86%20JTAG%20%E8%BF%9E%E6%8E%A5%E5%88%B0%E6%A0%87%E6%9C%89%20J6%20%E7%9A%84%2010%20%E9%92%88%E6%8F%92%E5%BA%A7%3C%2FSPAN%3E%3CBR%20%2F%3E%3CSPAN%20style%3D%22font-family%3A%20helvetica%3B%20font-size%3A%2012pt%3B%22%3E%E5%B0%86%20A%20%E5%9E%8B%E8%BD%AC%20A%20%E5%9E%8B%20USB%20%E7%BA%BF%E7%BC%86%E7%9A%84%E4%B8%80%E7%AB%AF%E8%BF%9E%E6%8E%A5%E5%88%B0%E6%A0%87%E6%9C%89%20USB0%20%E7%9A%84%E6%8F%92%E5%BA%A7%E3%80%82%E5%B0%86%E6%AD%A4%E7%BA%BF%E7%BC%86%E7%9A%84%E5%8F%A6%E4%B8%80%E7%AB%AF%E6%8F%92%E5%85%A5%20PC%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22min-height%3A%208pt%3B%20padding%3A%200px%3B%20color%3A%20%23646464%3B%20font-family%3A%20Arial%2C%20sans-serif%3B%20font-size%3A%2012px%3B%22%3E%3CSPAN%20style%3D%22font-family%3A%20helvetica%3B%20font-size%3A%2012pt%3B%22%3E%20%3C%2FSPAN%3E%26nbsp%3B%3C%2FP%3E%3CH2%20style%3D%22font-family%3A%20Lato%2C%20sans-serif%3B%20color%3A%20%23e66e08%3B%20font-size%3A%2018px%3B%20background%3A%200%2050%25%20%23ffffff%3B%22%20id%3D%22toc-hId--637100803%22%20id%3D%22toc-hId-285319725%22%3E%3CSPAN%20style%3D%22text-decoration%3A%20underline%3B%20font-family%3A%20helvetica%3B%20font-size%3A%2012pt%3B%22%3ELPC11u14_MCB1000%EF%BC%88Keil%20MCB1000%E5%BC%80%E5%8F%91%E6%9D%BF%EF%BC%89%3C%2FSPAN%3E%3C%2FH2%3E%3CP%20style%3D%22color%3A%20%23646464%3B%20font-family%3A%20Arial%2C%20sans-serif%3B%20font-size%3A%2012px%3B%22%3E%3CSPAN%20style%3D%22font-family%3A%20helvetica%3B%20font-size%3A%2012pt%3B%22%3E%E5%8E%9F%E7%90%86%E5%9B%BE%EF%BC%9A.%2FBSP%2Fschematics%2Fmcb1000-schematics.pdf%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22min-height%3A%208pt%3B%20padding%3A%200px%3B%22%3E%26nbsp%3B%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-family%3A%20helvetica%3B%20font-size%3A%2012pt%3B%22%3E%E8%B7%B3%E7%BA%BF%EF%BC%9A%3C%2FSPAN%3E%3CBR%20%2F%3E%20%3CSPAN%20style%3D%22font-family%3A%20helvetica%3B%20font-size%3A%2012pt%3B%22%3EJ4%20%3D%202-3%EF%BC%88UCON%20-%20PIO0_6%20%E5%B0%86%20D%2B%20%E6%8B%89%E9%AB%98%EF%BC%89%3C%2FSPAN%3E%3CBR%20%2F%3E%20%3CSPAN%20style%3D%22font-family%3A%20helvetica%3B%20font-size%3A%2012pt%3B%22%3EJ2%20%3D%201-2%EF%BC%88VDD%20-%20%E6%A0%B8%E5%BF%83%E7%94%B5%E6%BA%90%EF%BC%89%3C%2FSPAN%3E%3CBR%20%2F%3E%20%3CSPAN%20style%3D%22font-family%3A%20helvetica%3B%20font-size%3A%2012pt%3B%22%3EJ5%20%E6%9C%AA%E5%AE%89%E8%A3%85%EF%BC%88ISP%20-%20%E9%80%9A%E8%BF%87%20COMM%20%E7%9A%84%20ISP%EF%BC%89%3C%2FSPAN%3E%3CBR%20%2F%3E%20%3CSPAN%20style%3D%22font-family%3A%20helvetica%3B%20font-size%3A%2012pt%3B%22%3EJ6%20%E6%9C%AA%E5%AE%89%E8%A3%85%EF%BC%88RST%20-%20%E9%80%9A%E8%BF%87%20COMM%20%E7%9A%84%20ISP%EF%BC%89%3C%2FSPAN%3E%3CBR%20%2F%3E%3CSPAN%20style%3D%22font-family%3A%20helvetica%3B%20font-size%3A%2012pt%3B%22%3E%E5%B0%86%20JTAG%20%E8%B0%83%E8%AF%95%E5%99%A8%E8%BF%9E%E6%8E%A5%E5%88%B0%E6%A0%87%E6%9C%89%20J3%20%E7%9A%84%2010%20%E9%92%88%20Cortex%20%E8%B0%83%E8%AF%95%E8%BF%9E%E6%8E%A5%E5%99%A8%3C%2FSPAN%3E%3CBR%20%2F%3E%3CSPAN%20style%3D%22font-family%3A%20helvetica%3B%20font-size%3A%2012pt%3B%22%3E%E5%B0%86%20USB%20%E7%94%B5%E7%BC%86%E7%9A%84%20B%20%E5%9E%8B%E7%AB%AF%E8%BF%9E%E6%8E%A5%E5%88%B0%20PC%20%E4%B8%8A%E7%9A%84%20B%20%E5%9E%8B%E6%8F%92%E5%BA%A7%EF%BC%8C%E5%B0%86%E7%94%B5%E7%BC%86%E7%9A%84%20A%20%E5%9E%8B%E7%AB%AF%E8%BF%9E%E6%8E%A5%E5%88%B0%20PC%20%E4%B8%8A%E7%9A%84%20USB%20%E6%8F%92%E5%BA%A7%3C%2FSPAN%3E%3CBR%20%2F%3E%3CSPAN%20style%3D%22font-family%3A%20helvetica%3B%20font-size%3A%2012pt%3B%22%3E%E4%B8%80%E6%97%A6%20USB%20%E7%94%B5%E7%BC%86%E8%BF%9E%E6%8E%A5%E5%88%B0%E5%BC%80%E5%8F%91%E6%9D%BF%EF%BC%8C%E4%BB%A5%E4%B8%8B%20LED%20%E5%B0%B1%E4%BC%9A%E4%BA%AE%E8%B5%B7%EF%BC%9A%3C%2FSPAN%3E%3CBR%20%2F%3E%3CSPAN%20style%3D%22font-family%3A%20helvetica%3B%20font-size%3A%2012pt%3B%22%3E%E5%8A%9B%E9%87%8F%3C%2FSPAN%3E%3CBR%20%2F%3E%3CSPAN%20style%3D%22font-family%3A%20helvetica%3B%20font-size%3A%2012pt%3B%22%3EPIO2%20%E4%B8%AD%E7%9A%84%E6%89%80%E6%9C%89%208%20%E4%B8%AA%20LED%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22min-height%3A%208pt%3B%20padding%3A%200px%3B%20color%3A%20%23646464%3B%20font-family%3A%20Arial%2C%20sans-serif%3B%20font-size%3A%2012px%3B%22%3E%3CSPAN%20style%3D%22font-family%3A%20helvetica%3B%20font-size%3A%2012pt%3B%22%3E%20%3C%2FSPAN%3E%26nbsp%3B%3C%2FP%3E%3CH2%20style%3D%22font-family%3A%20Lato%2C%20sans-serif%3B%20color%3A%20%23e66e08%3B%20font-size%3A%2018px%3B%20background%3A%200%2050%25%20%23ffffff%3B%22%20id%3D%22toc-hId-1850412030%22%20id%3D%22toc-hId--1522134738%22%3E%3CSPAN%20style%3D%22text-decoration%3A%20underline%3B%20font-family%3A%20helvetica%3B%20font-size%3A%2012pt%3B%22%3ELPC1768_MCB1700%EF%BC%88Keil%20MCB1700%E5%BC%80%E5%8F%91%E6%9D%BF%EF%BC%89%3C%2FSPAN%3E%3C%2FH2%3E%3CP%20style%3D%22color%3A%20%23646464%3B%20font-family%3A%20Arial%2C%20sans-serif%3B%20font-size%3A%2012px%3B%22%3E%3CSPAN%20style%3D%22font-family%3A%20helvetica%3B%20font-size%3A%2012pt%3B%22%3E%E5%8E%9F%E7%90%86%E5%9B%BE%EF%BC%9A.%2FBSP%2Fschematics%2Fmcb1700-schematics.pdf%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22min-height%3A%208pt%3B%20padding%3A%200px%3B%22%3E%26nbsp%3B%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-family%3A%20helvetica%3B%20font-size%3A%2012pt%3B%22%3E%E8%B7%B3%E7%BA%BF%EF%BC%9A%3C%2FSPAN%3E%3CBR%20%2F%3E%20%3CSPAN%20style%3D%22font-family%3A%20helvetica%3B%20font-size%3A%2012pt%3B%22%3EE%2FU%20%3D%201-2%EF%BC%88%E4%BB%A5%E5%A4%AA%E7%BD%91%2FUSB%EF%BC%89%3C%2FSPAN%3E%3CBR%20%2F%3E%20%3CSPAN%20style%3D%22font-family%3A%20helvetica%3B%20font-size%3A%2012pt%3B%22%3EUMODE%20%3D%201-2%EF%BC%88USB%E8%AE%BE%E5%A4%87%E6%A8%A1%E5%BC%8F%EF%BC%89%3C%2FSPAN%3E%3CBR%20%2F%3E%20%3CSPAN%20style%3D%22font-family%3A%20helvetica%3B%20font-size%3A%2012pt%3B%22%3ED-%20%3D%20%E8%AE%BE%E5%A4%87%3C%2FSPAN%3E%3CBR%20%2F%3E%3CSPAN%20style%3D%22font-family%3A%20helvetica%3B%20font-size%3A%2012pt%3B%22%3ED%2B%20%3D%20%E8%AE%BE%E5%A4%87%3C%2FSPAN%3E%3CBR%20%2F%3E%3CSPAN%20style%3D%22font-family%3A%20helvetica%3B%20font-size%3A%2012pt%3B%22%3EVBUS%20%3D%201-2%3C%2FSPAN%3E%3CBR%20%2F%3E%20%3CSPAN%20style%3D%22font-family%3A%20helvetica%3B%20font-size%3A%2012pt%3B%22%3EVDDIO%20%3D%201-2%3C%2FSPAN%3E%3CBR%20%2F%3E%20%3CSPAN%20style%3D%22font-family%3A%20helvetica%3B%20font-size%3A%2012pt%3B%22%3EVDDREG%20%3D%201-2%3C%2FSPAN%3E%3CBR%20%2F%3E%3CSPAN%20style%3D%22font-family%3A%20helvetica%3B%20font-size%3A%2012pt%3B%22%3E%26nbsp%3B%20%3C%2FSPAN%3E%3CBR%20%2F%3E%3CSPAN%20style%3D%22font-family%3A%20helvetica%3B%20font-size%3A%2012pt%3B%22%3E%E5%B0%86%20JTAG%20%E8%B0%83%E8%AF%95%E5%99%A8%E8%BF%9E%E6%8E%A5%E5%88%B0%2020%20%E9%92%88%20JTAG%20%E6%88%96%2010%20%E9%92%88%20Cortex%20%E8%B0%83%E8%AF%95%E8%BF%9E%E6%8E%A5%E5%99%A8%E3%80%82%3C%2FSPAN%3E%3CBR%20%2F%3E%3CSPAN%20style%3D%22font-family%3A%20helvetica%3B%20font-size%3A%2012pt%3B%22%3E%E5%B0%86%20USB%20%E7%BA%BF%E7%BC%86%E7%9A%84%20B%20%E5%9E%8B%E7%AB%AF%E8%BF%9E%E6%8E%A5%E5%88%B0%E6%A0%87%E6%9C%89%E2%80%9C%E8%AE%BE%E5%A4%87%E2%80%9D%E7%9A%84%20B%20%E5%9E%8B%E6%8F%92%E5%BA%A7%EF%BC%8C%E5%B0%86%20USB%20%E7%BA%BF%E7%BC%86%E7%9A%84%20A%20%E5%9E%8B%E7%AB%AF%E8%BF%9E%E6%8E%A5%E5%88%B0%20PC%20%E4%B8%8A%E7%9A%84%20USB%20%E6%8F%92%E5%BA%A7%E3%80%82USB%20%E7%BA%BF%E7%BC%86%E8%BF%9E%E6%8E%A5%E5%88%B0%E5%BC%80%E5%8F%91%E6%9D%BF%E5%90%8E%EF%BC%8C%E4%BB%A5%E4%B8%8B%20LED%20%E5%BA%94%E4%BA%AE%E8%B5%B7%EF%BC%9A%3C%2FSPAN%3E%3CBR%20%2F%3E%3CSPAN%20style%3D%22font-family%3A%20helvetica%3B%20font-size%3A%2012pt%3B%22%3E%E5%8A%9B%E9%87%8F%3C%2FSPAN%3E%3CBR%20%2F%3E%3CSPAN%20style%3D%22font-family%3A%20helvetica%3B%20font-size%3A%2012pt%3B%22%3E100%E5%85%86%E8%B5%AB%3C%2FSPAN%3E%3CBR%20%2F%3E%3CSPAN%20style%3D%22font-family%3A%20helvetica%3B%20font-size%3A%2012pt%3B%22%3EUSC%EF%BC%88LED%20%E6%8C%87%E7%A4%BA%E6%9D%A5%E8%87%AA%20P2.9%20%E7%9A%84%20USB%20%E8%BD%AF%E8%BF%9E%E6%8E%A5%EF%BC%89%3C%2FSPAN%3E%3CBR%20%2F%3E%3CSPAN%20style%3D%22font-family%3A%20helvetica%3B%20font-size%3A%2012pt%3B%22%3E%26nbsp%3B%26nbsp%3B%20%3C%2FSPAN%3E%3C%2FP%3E%3CH2%20style%3D%22font-family%3A%20Lato%2C%20sans-serif%3B%20color%3A%20%23e66e08%3B%20font-size%3A%2018px%3B%20background%3A%200%2050%25%20%23ffffff%3B%22%20id%3D%22toc-hId-42957567%22%20id%3D%22toc-hId-965378095%22%3E%3CSPAN%20style%3D%22text-decoration%3A%20underline%3B%20font-family%3A%20helvetica%3B%20font-size%3A%2012pt%3B%22%3ELPC11Uxx_LPCXpressoRevB%EF%BC%88LPCXpresso%20Rev%20B%20%E5%9F%BA%E6%9D%BF%E4%B8%8A%E7%9A%84%20LPCXpresso%20LPC11Uxx%EF%BC%89%3C%2FSPAN%3E%3C%2FH2%3E%3CP%20style%3D%22color%3A%20%23646464%3B%20font-family%3A%20Arial%2C%20sans-serif%3B%20font-size%3A%2012px%3B%22%3E%3CSPAN%20style%3D%22font-family%3A%20helvetica%3B%20font-size%3A%2012pt%3B%22%3E%E5%8E%9F%E7%90%86%E5%9B%BE%EF%BC%9A.%2FBSP%2Fschematics%2Flpcxpresso.lpc11u14.schematic.pdf%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22min-height%3A%208pt%3B%20padding%3A%200px%3B%22%3E%26nbsp%3B%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-family%3A%20helvetica%3B%20font-size%3A%2012pt%3B%22%3E%E5%8F%AF%E4%BB%A5%E9%80%9A%E8%BF%87%E4%BB%A5%E4%B8%8B%E4%B8%A4%E7%A7%8D%E6%96%B9%E5%BC%8F%E4%B9%8B%E4%B8%80%E5%9C%A8%20LPCXpresso%20LPC11U14%20%E4%B8%8A%E8%BF%90%E8%A1%8C%E6%AD%A4%E7%A4%BA%E4%BE%8B%EF%BC%9A%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22min-height%3A%208pt%3B%20padding%3A%200px%3B%22%3E%26nbsp%3B%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-family%3A%20helvetica%3B%20font-size%3A%2012pt%3B%22%3E1.%20LPCXpresso%20LPC11U14%20%E7%8B%AC%E7%AB%8B%E7%89%88%3C%2FSPAN%3E%3CBR%20%2F%3E%3CSPAN%20style%3D%22font-family%3A%20helvetica%3B%20font-size%3A%2012pt%3B%22%3E%E5%B0%86%20USB%20%E7%BA%BF%E7%BC%86%E7%9A%84%20B%20%E5%9E%8B%E7%AB%AF%E8%BF%9E%E6%8E%A5%E5%88%B0%20LPCXpresso%20%E6%9D%BF%E4%B8%8A%E6%A0%87%E6%9C%89%20J8%20%E7%9A%84%E8%BF%B7%E4%BD%A0%E6%8F%92%E5%BA%A7%EF%BC%8C%E5%B0%86%20A%20%E5%9E%8B%E7%AB%AF%E8%BF%9E%E6%8E%A5%E5%88%B0%20PC%20%E4%B8%8A%E7%9A%84%20USB%20%E6%8F%92%E5%BA%A7%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22min-height%3A%208pt%3B%20padding%3A%200px%3B%22%3E%26nbsp%3B%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-family%3A%20helvetica%3B%20font-size%3A%2012pt%3B%22%3E2.%20%E5%B0%86%20LPCXpresso%20LPC11U14%20%E6%8F%92%E5%85%A5%20LPCXpresso%20%E5%BA%95%E6%9D%BF%20Rev%20B%3C%2FSPAN%3E%3CBR%20%2F%3E%3CSPAN%20style%3D%22font-family%3A%20helvetica%3B%20font-size%3A%2012pt%3B%22%3E%E5%B0%86%20LPCXpresso%20LPC11U14%20%E6%9D%BF%E6%8F%92%E5%85%A5%20LPCXpresso%20%E5%BA%95%E6%9D%BF%20Rev%20B%20%E4%B8%8A%E6%A0%87%E6%9C%89%20J4%20%E7%9A%84%E8%BF%9E%E6%8E%A5%E5%99%A8%3C%2FSPAN%3E%3CBR%20%2F%3E%3CSPAN%20style%3D%22font-family%3A%20helvetica%3B%20font-size%3A%2012pt%3B%22%3E%E6%A0%B9%E6%8D%AE%20Embedded%20Artists%20%E7%9A%84%E7%94%A8%E6%88%B7%E6%8C%87%E5%8D%97%E9%85%8D%E7%BD%AE%E5%9F%BA%E6%9D%BF%3C%2FSPAN%3E%3CBR%20%2F%3E%3CSPAN%20style%3D%22font-family%3A%20helvetica%3B%20font-size%3A%2012pt%3B%22%3E%E5%B0%86%20USB%20%E7%94%B5%E7%BC%86%E7%9A%84%E8%BF%B7%E4%BD%A0%20B%20%E5%9E%8B%E7%AB%AF%E8%BF%9E%E6%8E%A5%E5%88%B0%E5%9F%BA%E6%9D%BF%E4%B8%8A%E6%A0%87%E6%9C%89%20X1%20%E7%9A%84%E6%8F%92%E5%BA%A7%EF%BC%8C%E5%B0%86%20A%20%E5%9E%8B%E7%AB%AF%E8%BF%9E%E6%8E%A5%E5%88%B0%20PC%20%E4%B8%8A%E7%9A%84%20USB%20%E6%8F%92%E5%BA%A7%3C%2FSPAN%3E%3CBR%20%2F%3E%3CSPAN%20style%3D%22font-family%3A%20helvetica%3B%20font-size%3A%2012pt%3B%22%3E%E4%B8%80%E6%97%A6%20USB%20%E7%94%B5%E7%BC%86%E8%BF%9E%E6%8E%A5%E5%88%B0%E5%BC%80%E5%8F%91%E6%9D%BF%EF%BC%8C%E4%BB%A5%E4%B8%8B%20LED%20%E5%B0%B1%E4%BC%9A%E4%BA%AE%E8%B5%B7%EF%BC%9A%3C%2FSPAN%3E%3CBR%20%2F%3E%20%3CSPAN%20style%3D%22font-family%3A%20helvetica%3B%20font-size%3A%2012pt%3B%22%3ELED25%EF%BC%88%E7%94%B5%E6%BA%90%E6%80%BB%E7%BA%BF%EF%BC%89%3C%2FSPAN%3E%3CBR%20%2F%3E%20%3CSPAN%20style%3D%22font-family%3A%20helvetica%3B%20font-size%3A%2012pt%3B%22%3ELED26%EF%BC%883.3V%20%E5%AF%BC%E8%BD%A8%EF%BC%89%3C%2FSPAN%3E%3CBR%20%2F%3E%3CSPAN%20style%3D%22font-family%3A%20helvetica%3B%20font-size%3A%2012pt%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FSPAN%3E%3CBR%20%2F%3E%3CSPAN%20style%3D%22font-family%3A%20helvetica%3B%20font-size%3A%2012pt%3B%22%3E%E5%AF%B9%E4%BA%8E%E8%BF%99%E4%B8%A4%E7%A7%8D%E9%85%8D%E7%BD%AE%EF%BC%8CJTAG%20%E8%B0%83%E8%AF%95%E5%99%A8%E9%83%BD%E8%BF%9E%E6%8E%A5%E5%88%B0%20LPCXpresso%20LPC11U14%20%E6%9D%BF%E4%B8%8A%E6%A0%87%E6%9C%89%20J3%20%E7%9A%84%20mini%20USB%20%E6%8F%92%E5%BA%A7%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22min-height%3A%208pt%3B%20padding%3A%200px%3B%20color%3A%20%23646464%3B%20font-family%3A%20Arial%2C%20sans-serif%3B%20font-size%3A%2012px%3B%22%3E%3CSPAN%20style%3D%22font-family%3A%20helvetica%3B%20font-size%3A%2012pt%3B%22%3E%20%3C%2FSPAN%3E%26nbsp%3B%3C%2FP%3E%3CH2%20style%3D%22font-family%3A%20Lato%2C%20sans-serif%3B%20color%3A%20%23e66e08%3B%20font-size%3A%2018px%3B%20background%3A%200%2050%25%20%23ffffff%3B%22%20id%3D%22toc-hId--1764496896%22%20id%3D%22toc-hId--842076368%22%3E%3CSPAN%20style%3D%22text-decoration%3A%20underline%3B%20font-family%3A%20helvetica%3B%20font-size%3A%2012pt%3B%22%3ELPC17xx_LPCXpressoRevB%EF%BC%88LPCXpresso%20Rev%20B%20%E5%9F%BA%E6%9D%BF%E4%B8%8A%E7%9A%84%20LPCXpresso%20LPC17xx%EF%BC%89%3C%2FSPAN%3E%3C%2FH2%3E%3CP%20style%3D%22color%3A%20%23646464%3B%20font-family%3A%20Arial%2C%20sans-serif%3B%20font-size%3A%2012px%3B%22%3E%3CSPAN%20style%3D%22font-family%3A%20helvetica%3B%20font-size%3A%2012pt%3B%22%3E%E5%8E%9F%E7%90%86%E5%9B%BE%EF%BC%9A.%2FBSP%2Fschematics%2FLPCXpressoLPC1769revB.pdf%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22min-height%3A%208pt%3B%20padding%3A%200px%3B%22%3E%26nbsp%3B%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-family%3A%20helvetica%3B%20font-size%3A%2012pt%3B%22%3E%E5%8F%AF%E4%BB%A5%E9%80%9A%E8%BF%87%E4%BB%A5%E4%B8%8B%E4%B8%A4%E7%A7%8D%E6%96%B9%E5%BC%8F%E4%B9%8B%E4%B8%80%E5%9C%A8%20LPCXpresso%20LPC1769%20%E4%B8%8A%E8%BF%90%E8%A1%8C%E6%AD%A4%E7%A4%BA%E4%BE%8B%EF%BC%9A%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22min-height%3A%208pt%3B%20padding%3A%200px%3B%22%3E%26nbsp%3B%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-family%3A%20helvetica%3B%20font-size%3A%2012pt%3B%22%3E1.LPCXpresso%20LPC1769%E7%8B%AC%E7%AB%8B%E7%89%88%E3%80%82%E5%B0%86%20B%20%E5%9E%8B%20USB%20%E6%8F%92%E5%BA%A7%E7%84%8A%E6%8E%A5%E5%88%B0%E7%94%B5%E8%B7%AF%E6%9D%BF%E4%B8%8A%E5%B9%B6%E5%B0%86%E5%85%B6%E6%8E%A5%E7%BA%BF%E3%80%82%E6%9C%89%E5%85%B3%E8%AF%A6%E7%BB%86%E4%BF%A1%E6%81%AF%EF%BC%8C%E8%AF%B7%E5%8F%82%E9%98%85%E9%99%84%E5%B8%A6%E7%9A%84%E7%A4%BA%E6%84%8F%E5%9B%BE%E3%80%82%E5%B0%86%20USB%20%E7%94%B5%E7%BC%86%E7%9A%84%20B%20%E5%9E%8B%E7%AB%AF%E8%BF%9E%E6%8E%A5%E5%88%B0%20LPCXpresso%20%E6%9D%BF%E4%B8%8A%E7%9A%84%E6%8F%92%E5%BA%A7%EF%BC%8C%E5%B0%86%20A%20%E5%9E%8B%E7%AB%AF%E8%BF%9E%E6%8E%A5%E5%88%B0%20PC%20%E4%B8%8A%E7%9A%84%20USB%20%E6%8F%92%E5%BA%A7%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22min-height%3A%208pt%3B%20padding%3A%200px%3B%22%3E%26nbsp%3B%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-family%3A%20helvetica%3B%20font-size%3A%2012pt%3B%22%3E2.%20%E5%B0%86%20LPCXpresso%20LPC1769%20%E6%8F%92%E5%85%A5%20LPCXpresso%20%E5%BA%95%E6%9D%BF%20Rev%20B%E3%80%82%E5%B0%86%20LPCXpresso%20LPC1769%20%E6%9D%BF%E6%8F%92%E5%85%A5%20LPCXpresso%20%E5%BA%95%E6%9D%BF%20Rev%20B%20%E4%B8%8A%E6%A0%87%E6%9C%89%20J4%20%E7%9A%84%E8%BF%9E%E6%8E%A5%E5%99%A8%E3%80%82%E6%A0%B9%E6%8D%AE%20Embedded%20Artists%20%E7%9A%84%E7%94%A8%E6%88%B7%E6%8C%87%E5%8D%97%E9%85%8D%E7%BD%AE%E5%BA%95%E6%9D%BF%E3%80%82%E5%B0%86%20USB%20%E7%BA%BF%E7%BC%86%E7%9A%84%E8%BF%B7%E4%BD%A0%20B%20%E5%9E%8B%E7%AB%AF%E8%BF%9E%E6%8E%A5%E5%88%B0%E5%BA%95%E6%9D%BF%E4%B8%8A%E6%A0%87%E6%9C%89%20X1%20%E7%9A%84%E6%8F%92%E5%BA%A7%EF%BC%8C%E5%B0%86%20A%20%E5%9E%8B%E7%AB%AF%E8%BF%9E%E6%8E%A5%E5%88%B0%20PC%20%E4%B8%8A%E7%9A%84%20USB%20%E6%8F%92%E5%BA%A7%E3%80%82%3C%2FSPAN%3E%3CBR%20%2F%3E%3CSPAN%20style%3D%22font-family%3A%20helvetica%3B%20font-size%3A%2012pt%3B%22%3E%26nbsp%3B%26nbsp%3B%20%3C%2FSPAN%3E%3CBR%20%2F%3E%3CSPAN%20style%3D%22font-family%3A%20helvetica%3B%20font-size%3A%2012pt%3B%22%3E%E4%B8%80%E6%97%A6%20USB%20%E7%94%B5%E7%BC%86%E8%BF%9E%E6%8E%A5%E5%88%B0%E5%BC%80%E5%8F%91%E6%9D%BF%EF%BC%8C%E4%BB%A5%E4%B8%8B%20LED%20%E5%B0%B1%E4%BC%9A%E4%BA%AE%E8%B5%B7%EF%BC%9A%3C%2FSPAN%3E%3CBR%20%2F%3E%20%3CSPAN%20style%3D%22font-family%3A%20helvetica%3B%20font-size%3A%2012pt%3B%22%3ELED25%EF%BC%88%E7%94%B5%E6%BA%90%E6%80%BB%E7%BA%BF%EF%BC%89%3C%2FSPAN%3E%3CBR%20%2F%3E%20%3CSPAN%20style%3D%22font-family%3A%20helvetica%3B%20font-size%3A%2012pt%3B%22%3ELED26%EF%BC%883.3V%20%E5%AF%BC%E8%BD%A8%EF%BC%89%3C%2FSPAN%3E%3CBR%20%2F%3E%3CSPAN%20style%3D%22font-family%3A%20helvetica%3B%20font-size%3A%2012pt%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FSPAN%3E%3CBR%20%2F%3E%3CSPAN%20style%3D%22font-family%3A%20helvetica%3B%20font-size%3A%2012pt%3B%22%3E%E5%AF%B9%E4%BA%8E%E8%BF%99%E4%B8%A4%E7%A7%8D%E9%85%8D%E7%BD%AE%EF%BC%8CJTAG%20%E8%B0%83%E8%AF%95%E5%99%A8%E9%83%BD%E8%BF%9E%E6%8E%A5%E5%88%B0%20LPCXpresso%20LPC1769%20%E6%9D%BF%E4%B8%8A%E6%A0%87%E6%9C%89%20J3%20%E7%9A%84%E8%BF%B7%E4%BD%A0%20USB%20%E6%8F%92%E5%BA%A7%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3CH1%20style%3D%22font-size%3A%2026px%3B%20font-weight%3A%20400%3B%20color%3A%20%23333333%3B%20font-family%3A%20Lato%2C%20sans-serif%3B%22%20id%3D%22toc-hId-593933218%22%20id%3D%22toc-hId-1516353746%22%3E%3CSPAN%20style%3D%22font-family%3A%20helvetica%3B%20font-size%3A%2012pt%3B%22%3E%3CSTRONG%3E%3CBIG%3EPC%E9%85%8D%E7%BD%AE%3C%2FBIG%3E%3C%2FSTRONG%3E%3C%2FSPAN%3E%3C%2FH1%3E%3CP%20style%3D%22color%3A%20%23646464%3B%20font-family%3A%20Arial%2C%20sans-serif%3B%20font-size%3A%2012px%3B%22%3E%3CSPAN%20style%3D%22font-family%3A%20helvetica%3B%20font-size%3A%2012pt%3B%22%3E%E4%BD%BF%E7%94%A8%E8%BF%90%E8%A1%8C%20Windows%20XP%E3%80%81Vista%20%E6%88%96%207%20%E7%9A%84%20PC%20%E5%B0%86%E8%BF%9E%E6%8E%A5%E5%88%B0%E5%BC%80%E5%8F%91%E6%9D%BF%E7%9A%84%20USB%20%E7%94%B5%E7%BC%86%E7%9A%84%20A%20%E5%9E%8B%E7%AB%AF%E8%BF%9E%E6%8E%A5%E5%88%B0%20PC%20%E4%B8%8A%E7%9A%84%E4%B8%80%E4%B8%AA%20USB%20%E6%8F%92%E5%BA%A7%3C%2FSPAN%3E%3CBR%20%2F%3E%3CSPAN%20style%3D%22font-family%3A%20helvetica%3B%20font-size%3A%2012pt%3B%22%3E%E6%89%93%E5%BC%80%20Windows%20%E6%96%87%E4%BB%B6%E8%B5%84%E6%BA%90%E7%AE%A1%E7%90%86%E5%99%A8%E7%AA%97%E5%8F%A3%3CBIG%3E%3CSTRONG%3E%3CBR%20%2F%3E%3CBR%20%2F%3E%3C%2FSTRONG%3E%3C%2FBIG%3E%3C%2FSPAN%3E%3C%2FP%3E%3CH1%20style%3D%22font-size%3A%2026px%3B%20font-weight%3A%20400%3B%20color%3A%20%23333333%3B%20font-family%3A%20Lato%2C%20sans-serif%3B%22%20id%3D%22toc-hId--1213521245%22%20id%3D%22toc-hId--291100717%22%3E%3CSPAN%20style%3D%22font-family%3A%20helvetica%3B%20font-size%3A%2012pt%3B%22%3E%3CBIG%3E%3CSTRONG%3E%E6%9E%84%E5%BB%BA%E5%B9%B6%E8%B0%83%E8%AF%95%E7%A4%BA%E4%BE%8B%3C%2FSTRONG%3E%3C%2FBIG%3E%3C%2FSPAN%3E%3C%2FH1%3E%3CH2%20style%3D%22font-family%3A%20Lato%2C%20sans-serif%3B%20color%3A%20%23e66e08%3B%20font-size%3A%2018px%3B%20background%3A%200%2050%25%20%23ffffff%3B%22%20id%3D%22toc-hId-1403074307%22%20id%3D%22toc-hId--1969472461%22%3E%3CBR%20%2F%3E%3CSPAN%20style%3D%22text-decoration%3A%20underline%3B%20font-family%3A%20helvetica%3B%20font-size%3A%2012pt%3B%22%3ELPCXpresso%20IDE%3C%2FSPAN%3E%3C%2FH2%3E%3CP%20style%3D%22color%3A%20%23646464%3B%20font-family%3A%20Arial%2C%20sans-serif%3B%20font-size%3A%2012px%3B%22%3E%3CSPAN%20style%3D%22font-family%3A%20helvetica%3B%20font-size%3A%2012pt%3B%22%3E%E5%9C%A8%20IDE%20%E7%9A%84%E9%A1%B9%E7%9B%AE%E8%B5%84%E6%BA%90%E7%AE%A1%E7%90%86%E5%99%A8%E7%AA%97%E5%8F%A3%E4%B8%AD%EF%BC%8C%E5%8F%B3%E9%94%AE%E5%8D%95%E5%87%BB%20Example_MassStorageDevice%20%E9%A1%B9%E7%9B%AE%E5%B9%B6%E9%80%89%E6%8B%A9%20Debug%20As-%26gt%3BC%2FC%2B%2B%20MCU%20Application%3C%2FSPAN%3E%3CBR%20%2F%3E%3CSPAN%20style%3D%22font-family%3A%20helvetica%3B%20font-size%3A%2012pt%3B%22%3E%E5%9C%A8%20IDE%20%E4%B8%BB%E7%AA%97%E5%8F%A3%E4%B8%AD%E5%8D%95%E5%87%BB%20Run-%26gt%3BResume%20%E5%BC%80%E5%A7%8B%E8%BF%90%E8%A1%8C%E5%BA%94%E7%94%A8%E7%A8%8B%E5%BA%8F%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22min-height%3A%208pt%3B%20padding%3A%200px%3B%22%3E%3CSPAN%20style%3D%22color%3A%20%23646464%3B%20font-family%3A%20helvetica%3B%20font-size%3A%2012pt%3B%22%3E%20%3C%2FSPAN%3E%26nbsp%3B%3C%2FP%3E%3CH2%20style%3D%22font-family%3A%20Lato%2C%20sans-serif%3B%20color%3A%20%23e66e08%3B%20font-size%3A%2018px%3B%20background%3A%200%2050%25%20%23ffffff%3B%22%20id%3D%22toc-hId--404380156%22%20id%3D%22toc-hId-518040372%22%3E%3CSPAN%20style%3D%22text-decoration%3A%20underline%3B%20font-family%3A%20helvetica%3B%20font-size%3A%2012pt%3B%22%3EKeil%20uVision%204%20IDE%3C%2FSPAN%3E%3C%2FH2%3E%3CP%20style%3D%22color%3A%20%23646464%3B%20font-family%3A%20Arial%2C%20sans-serif%3B%20font-size%3A%2012px%3B%22%3E%3CSPAN%20style%3D%22font-family%3A%20helvetica%3B%20font-size%3A%2012pt%3B%22%3E%E5%9C%A8%E6%89%B9%E9%87%8F%E6%9E%84%E5%BB%BA%E7%AA%97%E5%8F%A3%E4%B8%AD%EF%BC%8C%E6%8C%89%E7%85%A7%E7%BC%96%E8%AF%91%E5%99%A8%E6%9E%84%E5%BB%BA%E9%85%8D%E7%BD%AE%E4%B8%AD%E7%9A%84%E8%AF%B4%E6%98%8E%E9%80%89%E6%8B%A9%E9%A1%B9%E7%9B%AE%E7%9B%AE%E6%A0%87%EF%BC%8C%E7%84%B6%E5%90%8E%E5%8D%95%E5%87%BB%E6%9E%84%E5%BB%BA%3C%2FSPAN%3E%3CBR%20%2F%3E%3CSPAN%20style%3D%22font-family%3A%20helvetica%3B%20font-size%3A%2012pt%3B%22%3E%E5%9C%A8%20IDE%20%E4%B8%BB%E7%AA%97%E5%8F%A3%E4%B8%AD%E5%8D%95%E5%87%BB%E2%80%9C%E8%B0%83%E8%AF%95%E2%80%9D-%26gt%3B%E2%80%9C%E5%90%AF%E5%8A%A8%2F%E5%81%9C%E6%AD%A2%E8%B0%83%E8%AF%95%E4%BC%9A%E8%AF%9D%E2%80%9D%EF%BC%8C%E5%8D%95%E5%87%BB%E2%80%9C%E8%B0%83%E8%AF%95%E2%80%9D-%26gt%3B%E2%80%9C%E8%BF%90%E8%A1%8C%E2%80%9D%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22min-height%3A%208pt%3B%20padding%3A%200px%3B%22%3E%3CSPAN%20style%3D%22color%3A%20%23646464%3B%20font-family%3A%20helvetica%3B%20font-size%3A%2012pt%3B%22%3E%20%3C%2FSPAN%3E%26nbsp%3B%3C%2FP%3E%3CH1%20style%3D%22font-size%3A%2026px%3B%20font-weight%3A%20400%3B%20color%3A%20%23333333%3B%20font-family%3A%20Lato%2C%20sans-serif%3B%22%20id%3D%22toc-hId-1954049958%22%20id%3D%22toc-hId--1418496810%22%3E%3CSPAN%20style%3D%22font-family%3A%20helvetica%3B%20font-size%3A%2012pt%3B%22%3E%3CBIG%3E%3CSTRONG%3E%E6%AD%A4%E7%A4%BA%E4%BE%8B%E5%A6%82%E4%BD%95%E8%BF%90%E8%A1%8C%E4%BB%A5%E5%8F%8A%E8%A6%81%E6%9F%A5%E6%89%BE%E7%9A%84%E5%86%85%E5%AE%B9%3C%2FSTRONG%3E%3C%2FBIG%3E%3C%2FSPAN%3E%3C%2FH1%3E%3CP%20style%3D%22color%3A%20%23646464%3B%20font-family%3A%20Arial%2C%20sans-serif%3B%20font-size%3A%2012px%3B%22%3E%3CSPAN%20style%3D%22font-family%3A%20helvetica%3B%20font-size%3A%2012pt%3B%22%3E%E5%BD%93%E8%BF%90%E8%A1%8C%E7%A4%BA%E4%BE%8B%E5%B9%B6%E4%B8%94%E7%94%B5%E8%B7%AF%E6%9D%BF%E9%80%9A%E8%BF%87%20USB%20%E7%94%B5%E7%BC%86%E8%BF%9E%E6%8E%A5%E5%88%B0%20PC%20%E6%97%B6%EF%BC%8C%E5%AE%83%E5%B0%86%E5%9C%A8%20PC%20%E4%B8%8A%E4%BD%9C%E4%B8%BA%E5%A4%A7%E5%AE%B9%E9%87%8F%E5%AD%98%E5%82%A8%E8%AE%BE%E5%A4%87%E6%9E%9A%E4%B8%BE%EF%BC%8C%E5%B9%B6%E5%9C%A8%20Windows%20%E6%96%87%E4%BB%B6%E8%B5%84%E6%BA%90%E7%AE%A1%E7%90%86%E5%99%A8%E4%B8%AD%E6%98%BE%E7%A4%BA%E4%B8%BA%E5%8D%B7%E6%A0%87%E4%B8%BA%E2%80%9CnxpUSBlib%E2%80%9D%E7%9A%84%E9%A9%B1%E5%8A%A8%E5%99%A8%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22min-height%3A%208pt%3B%20padding%3A%200px%3B%22%3E%26nbsp%3B%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-family%3A%20helvetica%3B%20font-size%3A%2012pt%3B%22%3E%E8%AF%A5%E9%A9%B1%E5%8A%A8%E5%99%A8%E5%B0%86%E5%8C%85%E5%90%AB%E4%B8%80%E4%B8%AA%E5%90%8D%E4%B8%BA%E2%80%9CREADME.TXT%E2%80%9D%E7%9A%84%E6%96%87%E4%BB%B6%EF%BC%8C%E5%85%B6%E4%B8%AD%E5%8C%85%E5%90%AB%E6%96%87%E6%9C%AC%E2%80%9C%E8%BF%99%E6%98%AF%E4%B8%80%E4%B8%AA%20USB%20%E5%AD%98%E5%82%A8%E8%AE%BE%E5%A4%87%E6%BC%94%E7%A4%BA%E2%80%9D%E3%80%82%E2%80%9C%3C%2FSPAN%3E%3C%2FP%3E%3CH1%20style%3D%22font-size%3A%2026px%3B%20font-weight%3A%20400%3B%20color%3A%20%23333333%3B%20font-family%3A%20Lato%2C%20sans-serif%3B%22%20id%3D%22toc-hId-146595495%22%20id%3D%22toc-hId-1069016023%22%3E%3CSPAN%20style%3D%22font-family%3A%20helvetica%3B%20font-size%3A%2012pt%3B%22%3E%3CSTRONG%3E%3CBIG%3E%E8%AE%BE%E8%AE%A1%E7%AC%94%E8%AE%B0%3C%2FBIG%3E%3C%2FSTRONG%3E%3C%2FSPAN%3E%3C%2FH1%3E%3CP%20style%3D%22color%3A%20%23646464%3B%20font-family%3A%20Arial%2C%20sans-serif%3B%20font-size%3A%2012px%3B%22%3E%3CSPAN%20style%3D%22font-family%3A%20helvetica%3B%20font-size%3A%2012pt%3B%22%3E%E6%AD%A4%E5%A4%A7%E5%AE%B9%E9%87%8F%E5%AD%98%E5%82%A8%E8%AE%BE%E5%A4%87%E7%A4%BA%E4%BE%8B%E5%AE%9A%E4%B9%89%E4%BA%86%E8%99%9A%E6%8B%9F%E9%A9%B1%E5%8A%A8%E5%99%A8%E5%A4%A7%E5%B0%8F%E5%92%8C%E7%89%A9%E7%90%86%E9%A9%B1%E5%8A%A8%E5%99%A8%E5%A4%A7%E5%B0%8F%E3%80%82%3C%2FSPAN%3E%3CBR%20%2F%3E%3CSPAN%20style%3D%22font-family%3A%20helvetica%3B%20font-size%3A%2012pt%3B%22%3E%E8%BF%99%E4%BA%9B%E6%95%B0%E5%AD%97%E5%9C%A8%E6%96%87%E4%BB%B6%20DataRam.h%20%E4%B8%AD%E5%AE%9A%E4%B9%89%EF%BC%8C%E5%A6%82%E4%B8%8B%E6%89%80%E7%A4%BA%EF%BC%9A%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22min-height%3A%208pt%3B%20padding%3A%200px%3B%22%3E%26nbsp%3B%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-family%3A%20helvetica%3B%20font-size%3A%2012pt%3B%22%3E%23%E5%AE%9A%E4%B9%89%E6%95%B0%E6%8D%AERAM%E8%B5%B7%E5%A7%8B%E5%9C%B0%E5%9D%80%200x20080000%3C%2FSPAN%3E%3CBR%20%2F%3E%20%3CSPAN%20style%3D%22font-family%3A%20helvetica%3B%20font-size%3A%2012pt%3B%22%3E%23%E5%AE%9A%E4%B9%89%E6%95%B0%E6%8D%AERAM%E7%89%A9%E7%90%86%E5%A4%A7%E5%B0%8F0xc00%3C%2FSPAN%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E
无评分
版本历史
最后更新:
‎04-25-2016 02:26 PM
更新人:
