"unresolved breakpoints"not stopping program
172件の閲覧回数
lpcware
Content originally posted in LPCWare by william.vh on Sun Jul 04 14:36:30 MST 2010
I'm using CodeRed 3.4 on WindowsXP with a lpc1343 xpresso board.
Breakpoints show problem "unresolved break point" and do not actually stop the program.
Suggestion on what to check.
Breakpoints are working on Blinky so hardware is OK.
165件の閲覧回数
lpcware
Content originally posted in LPCWare by CodeRedSupport on Sun Jul 04 23:11:01 MST 2010
Can you remove the *.launch files from your project and then try debugging again. If that doesn't solve the problem, can you say *exactly* what you are doing.
