What does "Erase by page" function do?
lpcware
Content originally posted in LPCWare by c0dehunter on Thu May 29 23:25:53 MST 2014
There is an alternative option under Erase flash memory tab, called Erase by page, versus Mass Erase. What does this option do?
[IMG]http://i.imgur.com/pthkMTZ.png[/IMG]
lpcware
Content originally posted in LPCWare by lpcxpresso-support on Fri May 30 01:09:58 MST 2014
Erase by page will loop through erasing every page in your flash device.
Mass erase will use the Flash's "erase device" function (if it exists). If the device does not support Mass erase, then Erase by page will be performed instead.
Mass erase is generally quicker.
