Content originally posted in LPCWare by JSalisbury on Tue Mar 22 08:43:27 MST 2011
Yes it was a problem when useing the quick start -> build project. The issue has gone away for the moment. There may have been an issue with the example set for both the 301 and 302 varients in the same workspace. It now seems to work now that I only have the 302 varient samples and the CMSISv1p30_LPC11xx libary in the workspace.
Quote: CodeRedSupport
So the fundamental question is - is your problem actually a build failure when you choose [B][FONT=Courier New][SIZE=2]Quickstart -> Build <project>[/SIZE][/FONT][/B], or is your issue just that the indexer not having indexed your source files yet?
CodeRedSupport
