Measure the current consumption of each pipeline stage at every clock cycle by LPCXpresso IDE's Power Measurement Tool
832件の閲覧回数
himanshudoshi
Hello to all,
I am trying to measure the current consumption by different instructions. To achieve this, I am feeding my instructions as an interrupt. The piece of code is below:
//Interrupt
void SysTick_Handler(void)
asm(
         add....
         nop...
//MAIN Function
int main(void){
      int p = 1;
while(1){
               __WFI();
return 0;
Now, I wanted to know the consumption of current on every clock cycle and I wanted to measure for each pipeline stage (Instruction Fetch, Instruction Decode and Execution). As, I am at beginner level, in this field. Your help will be a great help.
It will be great, if you can provide me a sample code or some documentation regarding this issue. As I am very much new in the coding also. (My board is LPCXpresso 54114)
Thank you very much and regards,
Himanshu Doshi
0 返答(返信)
