Content originally posted in LPCWare by borik2003 on Mon Nov 15 04:51:18 MST 2010
Thank for Help.
I did what you write below ,
And i have 6.8K code increasing when add sqrt() function and
onather 2k when add aditional pow() function from same math.h librery
I did compere it against Keil compiler and i get different results:
for adding sqrt() function , code increase = 560 byte
for adding pow() function , code incr. = 3.7k byte
I can't explain why there are so big differences when using standard C functions
for the same Core but with different compilers .
