i am starting to maintain an old IAR project
there is a global variable, volatile dali_terminal_t terminal_arr[64] = {0};
terminal_arr is about 768 bytes.
below figure is before the statement: terminal_arr[addr].group_low = backcmd; // backcmd is 0x86
after run the statement, group_low value has lost.
im new to LPC , dont know how to debug it and so hope you could give a hand.
Hi jay ch,
I'd like to know which IDE you use, and the version of it.
TIC
Hi jay ch,
I will check it later, I think there's an issue about the IDE, maybe you can also seek for some support from the IAR via the https://www.iar.com/support/#!?tab=resources
TIC
