how to run LPCXpresso Development Board
748 次查看
frank_pan
I received a LPCXpresso Development Board for LPC5460x MCUs, however no power supply and cable included.  How should I run this demo board?  Thanks for your help.
571 次查看
frank_pan
It works now.  J1 doesn't work, so I use J8 for power supply.
571 次查看
frank_pan
Hi Sol,
Thanks for your reply.  However when I connect the mini USB cable with the power (it is tested with my other device), the board didn't turn on and no any lights were on either.
Do you know what could be the cause of the problem?  How should I trouble shoot this issue?
Frank
572 次查看
frank_pan
571 次查看
soledad
You need to connect a micro USB cable from connector J8 or J1 to a power source (computer or power supply).
This USB cable is not included in the board.
You can check more information about the board connection in the user guide:
https://www.nxp.com/docs/en/user-guide/UM11035.pdf
Sol
