avoiding LPC51U68 enter to ISP mode
754 次查看
gschelotto
Contributor V
I'm afraid my LPC51U68 is entering to ISP mode and I see in the UM the next statement:
How can I do this?
regards,
gaston
744 次查看
ZhangJennie
What specific problem do you have?
Can you access debug via SWD?
Can your board enter ISP mode?
Did you set CRP in source code?
Jun Zhang
717 次查看
gschelotto
Contributor V
Pin2 (PIO0_24) is stuck at 0V after reset and I cannot toggle this digital output to high.
Yes, there is no problem with this.
I would say no since PI00_31 = 3.3V at Power Up through a 47k pull-up .
No
regards,
gaston
698 次查看
ZhangJennie
I read your description I wonder the problem is not related with CRP but on your code.
Do you use a custom designed board or NXP demo boa? Could you please try to debug a MCUXpresso SDK demo led_output to check if it can blink a gpio correctly? If you have NXP demo board, it's good to test led_output on demo code as well.
Jun Zhang
