USART interrupt
USART interrupt
1,187 次查看
rudomanenko
Hi everyone! I am trying to implement connection between Smart Card and LPC11Uxx via USART using interrupt. Current level - get ATR. Without interrupt everything works well, but with them - everything is crashing. Here is screenshots of my code below. Maybe I don't undestand how to work with interrups?
P.S. I already saw NXP emaples and even with them it is not so clear for me
5 回复数
983 次查看
jeremyzhou
Hi Anton Rudomanenko,
Actually, I don't find some clues after reviewing the screenshots and I'd like to get more information, so I was wondering if you can introduce the issue in details.
TIC
984 次查看
rudomanenko
thank again, dear jeremyzhou. But the problem was in startup file)
984 次查看
jeremyzhou
Thanks for your reply.
Maybe I can send you an updated startup file if you can tell me which IDE you use.
TIC
984 次查看
rudomanenko
I think that the reason is that this project was inherited by me from the other programmer, who commented line with necessary interrupt
984 次查看
michalisantonio
How to configure CTS pin, flexomm1, of QN9080DK to communicate to RTS pin of USART to RS485 converter?
I use usart_interrupt SDK example but can only send when connect RTS pin of USART to RS485 converter to  QN9080DK ground. QN9080DK can only receive when connect RTS pin of USART to RS485 converter to QN9080 3.3V.
I use following set up in pin_mux.c but doesn't work when use CTS
