Content originally posted in LPCWare by emp on Fri Sep 05 06:32:02 MST 2014
currently i am building a ws2812 driver using the spi interface of the LPC11C14 (later it should run on a LPC1113).
The user manual on page 234 says "In this configuration, during idle periods: ... The transmit MOSI/MISO pad is in high impedance.". In this configuration means CPOL 0, CPHA 1 in my case. However this sentence is used for every CPOL, CPHA combination.
My Scope shows, that the MOSI line is high in the idle state. I have added an external 10 KOhm Resistor between ground and MOSI (Pull-Down).
Is there something wrong in my initialisation or is this an undocumentent fault? The errata sheet does not mention the spi. A search in this forum and the internet revealed nothing
//MOSI, No PULL-UP/DOWN, No Hystersis, No Open Drain
LPC_IOCON->PIO2_3 = (0x02 << 0) | (0x00 << 3) | (0x00 << 5) | (0x00 << 10);
//SSL1
LPC_IOCON->PIO2_0 = (0x02 << 0) | (0x00 << 3) | (0x00 << 5) | (0x00 << 10);
//Hardware init (SSP1)
LPC_SYSCON->SYSAHBCLKCTRL |= (1 << 18); //Power
LPC_SYSCON->SSP1CLKDIV = 1;
LPC_SYSCON->PRESETCTRL &= ~(1 << 2); // Reset
LPC_SYSCON->PRESETCTRL |= (1 << 2); //Reset end
//16 Bit Transfer, SPI Mode, CPOL 0, CPHA 1, Serial Clock Rate
LPC_SSP1->CR0 = (0x0F << 0) | (0x00 << 4) | (0x00 << 6) | (0x01 << 7) | ((SystemAHBFrequency / (5000000 -1)) << 8);
// No Loopback mode, SPI Disable, Master
LPC_SSP1->CR1 = (0x00 << 0) | (0x00 << 1) | (0x00 << 2);
//Clockprescaler to minimal value
LPC_SSP1->CPSR = 2;
LPC_SSP1->CR1 |= (1 << 1); //enable spi
I do not need the SCK and MISO Pins. Even SSL is for debugging only.
Thanks emp
