SCT input detecting rising edge
292 次查看
lpcware
Content originally posted in LPCWare by temp88 on Thu Mar 24 06:20:54 MST 2016
i'm using LPC43xx, and i need to count the number of rising edge of an external signal.
i'd like to use SCT register for counting those edge (the signal is fast).
i have some problem on setting up the chosen sct pin as input, or in finding some example code with sct timer used as input.
Regards.
252 次查看
lpcware
bump
