RTC on LPC1788 counts wierd?
418件の閲覧回数
lpcware
Content originally posted in LPCWare by FrankAndersen on Tue Apr 08 05:36:13 MST 2014
Hi All,
I think I have seen this in a forum somewhere before, but I can not find it.
I have a design with LPC1788, where I want to use the internal RTC. On some of the boards, it counts time just fine.
But now I have one where it increases both hours, minutes and seconds every seconds, it is proberly some kind of test mode.
But where is it enabled/ disabled, and why does it not disapear when the power is removed from the RTC.
I am begining to have doubts about using the internal RTC of the LPC1788, as I see all kind of topics regarding this?
Frank Andersen
2 返答(返信)
353件の閲覧回数
lpcware
Content originally posted in LPCWare by FrankAndersen on Tue Apr 08 23:03:09 MST 2014
Thank you.
Some how I came to the conclussion that 0x09, was Clk bit and Cal bit.
So now I am able to get it counting right.
Anyone out there using the internal rtc in LPC1788, with good expirences?
Frank Andersen
353件の閲覧回数
lpcware
Content originally posted in LPCWare by LabRat on Tue Apr 08 07:12:23 MST 2014
Welcome to the Internal test mode :)
UM:
Quote:
Internal test mode controls. These bits must be 0 for normal RTC operation.
IIRC this mode can be enabled in CCR register. Check all bits there and reset the unused...
