Pulse counter using Timer
1,146件の閲覧回数
rajani_sureja33
Is it possible to use timer to count the pulses ??? if yes then how??
7 返答(返信)
833件の閲覧回数
rajani_sureja33
I am getting the pclk freq but don't get external input freq, Can anyone suggest me what has been remained to select external input on this pin?.
833件の閲覧回数
rajani_sureja33
Instant help will be appreciated:smileyhappy:
833件の閲覧回数
rajani_sureja33
This is the P1.0 (Timer1/capture1) initialization code for rpm reading.
TIM_COUNTERCFG_Type TIM_FanspeedTimerConfig;
TIM_CAPTURECFG_Type TIM_FanspeedCaptureConfig;
TIM_FanspeedCaptureConfig.CaptureChannel = TIM_COUNTER_INCAP1;
TIM_FanspeedCaptureConfig.RisingEdge = ENABLE;
TIM_FanspeedCaptureConfig.FallingEdge = DISABLE;
TIM_FanspeedCaptureConfig.IntOnCaption = DISABLE;
TIM_ConfigCapture(LPC_TIMER1,&TIM_FanspeedCaptureConfig);
TIM_ResetCounter(LPC_TIMER1);
TIM_Cmd(LPC_TIMER1,ENABLE);
833件の閲覧回数
rajani_sureja33
I am using Timer0 to generate an interrupt at every 1sec and I am reading capture value at pin 1.0 to count value of rpm. is it a right way to measure the rpm of fan?
But, I m still not getting actual rpm reading on this pin.
Can you please advice me asap?
833件の閲覧回数
soledad
Please check the below thread and let me know if this helps.
Any example to use CAPTURE PINS as pulse counters? | www.LPCware.com
Sol
833件の閲覧回数
soledad
Could you please mention the device you are using?
Sol
833件の閲覧回数
rajani_sureja33
we are using lpc1833 on P1.0
