Problems in the LPC11UXX SVD file
724 次查看
raphael_nestler
I've been working on LPC11Uxx register mappings for the Rust language using this SVD file.
The SVD file has some problems which I had to fix for my project. I hope those fixes can be applied to the original file, so others may benefit.
1. Duplicate Names
Various enumerated values have identical names, leading to duplicate names in the generated code. Fix: Fix duplicate names in SVD file · coredump-ch/lpc11uxx-rs@82663b4 · GitHub
2. Double underscores (_) in names
This is more a stylistic issue, but leads to warnings in the generated code. Fix: Fix snake_case errors in SVD file · coredump-ch/lpc11uxx-rs@45f0653 · GitHub
3. Reset value of the SYSAHBCLKCTRL register seems wrong
The reset value of the System clock control register seems to be wrong. According to the data-sheet it is 0x3F, but in the SVD file it is 0x0801485F. Fix: Fix reset value of the SYSAHBCLKCTRL register · coredump-ch/lpc11uxx-rs@384788a · GitHub
These are the issues I encountered so far. I can report any further problems as I find them if desired.
Thanks a lot,
Raphael
标记 (2)
611 次查看
jeremyzhou
Hi Raphael Nestler,
Thanks for your reporting.
TIC
611 次查看
mail9
I am also affected by these problems in the SVD files. I'm also relying on the files for code generation. jeremyzhou‌ are there already news on whether this could be forwarded to the responsible persons?
It would be great if the problems could be fixed for all NXP SVD files, so that other people that use these files can benefit from the fixes too.
