Microcontroller recommendation
Nadia
Hi all, I would like to know any MCU that you recommend that is similar to the LPC54616J, I have been using that family but I would like to use another family with similar characteristics.
Thank you very much.
diego_charles
Hi @Nadia
There are several  members of the LPC54000 series and they have different features. The below LPC  brochure may be helpful to check them easily:
https://www.nxp.com/docs/en/brochure/LPC-MCUs-INNOVATION-MADE-EASY.pdf#page=18
Similarly    @converse and @frank_m  , comments you could let us know if you require any particular feature, so we could provide  you more pointers to migrate to another MCU series.
Diego
frank_m
Senior Contributor III
To add to converse's recommendation, some background of the intended project would be helpful.
Many commercial developments go for the cheapest MCU that does the job - literally.
Other, less mass-market focussed projects use to take platform compatibility and toolchain environment into account.
converse
Senior Contributor V
Perhaps you can explain what you need that is different to LPC54616J? (and what  is wrong - from your point of view - with LPC54616? Do you want NXP or other vendor? DO you want Cortex-M4 or a different core? What peripherals do you need?
