LPCLink-2 (As Evaluation Board) Double Powered?
350件の閲覧回数
lpcware
Content originally posted in LPCWare by MikeSimmonds on Fri Mar 13 23:06:32 MST 2015
What happens when a LPCLink-2 board is powered both by the probe (probe has J2 closed) AND by
USB (target is connected to PC). Will I damage the target LPCLink-2?
How does this affect resetting. Via debug launch, via plug/unplug (target) USB cable.
Regards, Mike.
2 返答(返信)
344件の閲覧回数
lpcware
Content originally posted in LPCWare by MikeSimmonds on Mon Mar 16 17:17:28 MST 2015
Thank you very very much for that.
That is what I was hoping for, but I am a software guy not a hardware expert.
The reason: I would like to 'reset' the target and re-download edited code via dfu,
but it is always nice not to have to 'loose' the debugger on the other board.
Regards, Mike
344件の閲覧回数
lpcware
Content originally posted in LPCWare by starblue on Mon Mar 16 04:17:52 MST 2015
That connects the outputs of the 3.3V regulators on the two boards. But since the XC6227 regulator has reverse current protection that shouldn't be a problem (no guarantees, please check schematics and data sheet for yourself).
Basically the target board will be powered when at least one of the power sources is available.
