LPC824 I2C2 Drops a Clock
946件の閲覧回数
lpcware
Content originally posted in LPCWare by FirmLogic on Fri Jan 09 22:13:07 MST 2015
Our firmware experiences failed CRC checks occasionally. Using scope and logic analyzer, we tracked down to the I2C2 device issuing a NAK when firmware sent a "Continue" command.  Does not occur on any other I2C port.  What may be causing this problem?
Using LPCopen library.  Using I2C1, 2, & 3 as SMBus running at 100KHz.
- Mike Dawson -
0 返答(返信)
