In the LPC55xxx parts, the SYSCON block has a DEVICE_ID0 register which, according to the header file, includes the fields:
PARTCONFIG
SRAM_SIZE
FLASH_SIZE
ROM_REV_MINOR
MODELNUM_EXTENTION
But what do these fields actually _mean_: the user manual (UM11126) shows no information.
(What I'd actually like to do is distinguish between an LPC55S28 and an LPC5528 at run time.)
The fields that I mentioned are in the header file, not in the UM11126 (which is partly why I raised the question)
If the DEVICE_ID0 register isn't suitable for differentiating between LPC55xx variants, what is the official way of doing that? I would like to determine at run time which part I'm running on
These fields were in LPC55S69_cm33_core0.h (the version I looked at was version 1.0 and dated 2018-08-22).
As I said I would like to be able to identify the particular part ayt run time : how do I do that?
By checking internally, I can confirm LPC55 doesn't have feature of reading part number, as i said before.
User needs to know the part number and write it in Flash during programming the code.
Have a nice day
Jun Zhang
The LPC55S6x/LPC55S2x User Manual (UM11126) revision 2.4 has the following values listed:
I have an LPCXpresso 55S28, and the DEVICE_ID0 register on that reads as 0xA010119C. It must be a Rev 1B.
I'd like to know the value for LPC55S26, LPC5528, LPC5526, for both rev 1B and 0A. Please NXP tell us the values for all the LPC55xx processors.
I now have a board with LPC55S26 on it. The SYSCON DEVICE_ID0 is 0xA010229A.
I notice that using Flash Magic (13.61), it is missing signature values for a number of processors in the LPC55xx list. For some processors, it has a good signature value, but for others it just has 0x00000000.
I'm glad you confirmed this as I was puzzled by the missing signature in Flash Magic, too.
HI
For LPC55, only ROM version of DEVICE_ID0 is open to external.
Do you see below definition in SDK files? Please let me know the position, I will check.
PARTCONFIG
SRAM_SIZE
FLASH_SIZE
ROM_REV_MINOR
MODELNUM_EXTENTION
We can read part number from ROM for some of NXP LPC parts(for example LPC824). But LPC55 doesn't have this feature.
Best Regards
Jun Zhang
