LPC55S69 keil编译问题
LPC55S69 keil编译问题
1,806 次查看
haifeng_jin
在编译LPC55S69的SDK出现如下问题,pack都是安装的,不知道是什么问题,有遇到过吗
ArmClang: error: ARM Compiler does not support '-mcpu=cortex-m33'
4 回复数
1,609 次查看
Hello  haifeng jin,
Yes, as sean said, you need Professional license.
Do you still have question about this?
1,609 次查看
robertboys
Hello
Starting with Keil MDK 5.31, a MDK Pro license will not be needed for Armv8-M (Cortex-M23, M33, and so on).
Other versions of MDK will work with these TrustZone processors.
Even MDK-Lite (the evaluation version) will work to 32K.
MDK 5.31 is expected to be released early July 2020.
I just updated my LPC55S69 lab:   www.keil.com/appnotes/docs/apnt_322.asp
1,609 次查看
haifeng_jin
ok,谢谢,确实是licensec问题
1,609 次查看
seanzhou
LPC55 is ARM V8 cortex m33.
You need professional Keil version to compile it.
