LPC54018, JLink, IAR I cannot flash hello_world
849件の閲覧回数
danielgull
I am having trouble to flash hello world onto my target board LPC54018 OM40003.
I am trying to flash the demo application
SDK_2.7.0_LPCXpresso54018\boards\lpcxpresso54018\demo_apps\hello_world\iar\hello_world.eww
using the following toolchain: IAR 8.22.1.15700 and CMSIS DAP with the onboard Debug Link and a USB cable connected to the PC. However I cannot flash at all. I get a pop up window with the CMSIS-DAP error message "Fatal error: Probe not found. How can I get this board up and running so that I can work with it? This is already the second board that is not working out of the box.
Many thanks
Dani
2 返答(返信)
742件の閲覧回数
jeremyzhou
Hi Daniel Gull,
Thank you for your interest in NXP Semiconductor products and
for the opportunity to serve you.
Regarding your issue, I'd like to suggest you try the following steps to fix the issue.
1. Please assure the hardware setup is correct via referring to the attachment.
2. Update the firmware of the on-board Debug Probe.
TIC
742件の閲覧回数
danielgull
Hi Jeremey,
I updated according to the attached manual and the system is running again. I will continue to moitor the situation.
Many thanks
Dani
