LPC4337 spifif add support mx25l25635f
771件の閲覧回数
leohong
I use the MX25L25635F for LPC4337, but the lpcspifi library does not support this flash,
I try to add some configuration to rebuild library,
but it alwary return device is locked error.
Could you kindly support me to make a new library for mx25l25635f?
SPIFI Lib Version 0111
SPIFI clock rate 995121
FAMILY: Common SPIFI Command Set
Device family = MX25FL25635F
Capabilities = 0x1009d
Device size = 33554432
Max Clock Rate = 80000000
Erase blocks = 512
Erase block size = 65536
Erase sub-blocks = 8192
Erase sub-blocksize = 4096
Write page size = 256
Max single readsize = 16128
Current dev status = 0x0
Current options = 0
SPIFI final Rate = 68000000
Unlocking device...
Erasing device...
EraseBlocks() Error:5 Device is locked
Original Attachment has been moved to: spifilib_fam_standard_cmd.c.zip
ラベル(3)
3 返答(返信)
497件の閲覧回数
soledad
Hi Leo,
Please check the below comment:
Soledad
497件の閲覧回数
leohong
Hi soledad,
Thank you for your reply.
I know the flash can support boot from spifi.
My problem is that I want to download FW to flash MX25l25635F by KEIL,
So I need an algorithm to programming the flash,
According to Keil document "ULINKpro User's Guide: Creating Flash Programming Algorithms
Creating Flash Programming Algorithms"
The Algorithms project use the SPIFI library to read/write flash,
I download the source code of spifi library,
It does not include mx25l25635f parameters inside,
So I rebuild the library project, but it can not work after Erasing device...
The error message as below:
Please help me to creating an new flash programming algorithm for mx25l25635f.
Thank you.
497件の閲覧回数
leohong
Hi, I need help~
Please share some information to me.
Thank you.
