LPC4330 UARTbaudrate
467件の閲覧回数
tomsaluzzo
Page 1134 of the User Manual gives the equation for the UARTbaudrate. Section 40.6.3 on page 1123 of the User Manual states that :”… the baud rate clock, which must be 16x the desired baud rate”. Does this mean that the UARTbaudrate equation on page 1134 must generate a baud rate that is 16x the desired baud rate?
The following UARTbaudrate equation is copied from page 1134 of the User Manual:
 UARTbaudrate = PCLK / (16*(256*DLM+DLL)*(1+DivAddVal/MulVal)).
Is the above equation correct or should the equation be (note added parentheses around (DLM + DLL)):
 UARTbaudrate = PCLK / (16*(256*(DLM+DLL))*(1+DivAddVal/MulVal))?
303件の閲覧回数
mikesimmonds
The equation is correct as is (and wrong with your change). DLM and DLL are 8 bit quantities, so to get the 16 bit
divisor: 256 * (most significant byte) + (least significant byte) [Computer Science 101 Duh]
The factor of 16 is built in to the equation (the 16 in the divisor part) so go for 9600, 19200 etc. as one might expect.
Cheers, Mike.
