LPC1769: pwm cannot run at the same time
1,022件の閲覧回数
lpcware
Content originally posted in LPCWare by Wilbur He on Tue Feb 24 04:59:26 MST 2015
I have configured pwm1.2 and 1.3 to control 2 servo motors, however, only pwm1.3 can run properly, pwm1.2 cannot work unless i disable the pwm1.3 in init_PWM, why? I will be very appreciated if anyone can help me solve this problem.
16 返答(返信)
995件の閲覧回数
lpcware
Content originally posted in LPCWare by SirLelox on Sat Jun 06 07:24:37 MST 2015
yep this is the solution for me too!  :D
995件の閲覧回数
lpcware
Content originally posted in LPCWare by Wilbur He on Tue Feb 24 05:57:16 MST 2015
I change the "=" in init_pwm to "|=", now it's working!! thanks! i will read that tutorial carefully later, thanks!!!
995件の閲覧回数
lpcware
Content originally posted in LPCWare by Wilbur He on Tue Feb 24 05:56:36 MST 2015
995件の閲覧回数
lpcware
Content originally posted in LPCWare by Wilbur He on Tue Feb 24 05:54:12 MST 2015
I am really really very appreated for your help, i try to check it one more time
995件の閲覧回数
lpcware
Content originally posted in LPCWare by starblue on Tue Feb 24 05:45:52 MST 2015
Quote: Wilbur He
why they can't be set at the same time?, they are different bits)
You have to set them at the same time, in a single assignment. You do it by two assignments, so the bits for the first part are overwritten in the second assignment.
995件の閲覧回数
lpcware
Content originally posted in LPCWare by Wilbur He on Tue Feb 24 05:45:02 MST 2015
Sorry I quickly read that tutorial. The problem might be the register can't be accessed by bits?Thank you for your patience!! If I delete one pwm configuration in init_pwm, I can just control one servo. where should put another pwm configuration?
995件の閲覧回数
lpcware
Content originally posted in LPCWare by R2D2 on Tue Feb 24 05:33:49 MST 2015
Quote: Wilbur He
I think this is trying to set both p2.1 and p2.2's function to be pwm1.2 and 1.3,
Yes  :)
Quote: Wilbur He
(but I know it's wrong now, why they can't be set at the same time?, they are different bits)
Did you miss the lesson 'bitwise operators' last week  :quest:
That's basic stuff  :O
See: http://www.cprogramming.com/tutorial/bitwise_operators.html
995件の閲覧回数
lpcware
Content originally posted in LPCWare by Wilbur He on Tue Feb 24 05:27:28 MST 2015
PINSEL4 Pin name Function when 00 Function when 01 Function when 10 Function when 11
               1:0 P2.0   GPIO Port 2.0       PWM1.1                    TXD1                 Reserved
               3:2 P2.1   GPIO Port 2.1       PWM1.2                    RXD1                 Reserved
               5:4 P2.2   GPIO Port 2.2        PWM1.3                    CTS1                 Reserved
I think this is trying to set both p2.1 and p2.2's function to be pwm1.2 and 1.3, So I thought the result is d. (but I know it's wrong now, why they can't be set at the same time?, they are different bits)
995件の閲覧回数
lpcware
Content originally posted in LPCWare by R2D2 on Tue Feb 24 05:25:43 MST 2015
Come on, I'm waiting...
995件の閲覧回数
lpcware
Content originally posted in LPCWare by R2D2 on Tue Feb 24 05:17:58 MST 2015
LPC_PINCON->PINSEL4 = 1 << 2; //P2.1 works as PWM1.2 output.pin43,MR2
LPC_PINCON->PINSEL4 = 1 << 4; //P2.2 works as PWM1.3 output.pin44,MR3
What do you think, which bits are set in (32bit) register PINSEL4 now  :quest:
a: bit2
b: bit4
c: bit6
d: bit2 and bit4
e: no bits are set
995件の閲覧回数
lpcware
Content originally posted in LPCWare by Wilbur He on Tue Feb 24 05:13:37 MST 2015
I am sorry that I still don't quite understand, Which line should I delete, I set two registers here.... Crying  Crying (you are so nice, i saw you replied many posts in this forum)
995件の閲覧回数
lpcware
Content originally posted in LPCWare by Wilbur He on Tue Feb 24 05:11:19 MST 2015
I am sorry that I still don't quite understand, Which line should I delete, I set two registers here.... :((  :((  (you are so nice, i saw you replied many posts in this forum)
995件の閲覧回数
lpcware
Content originally posted in LPCWare by R2D2 on Tue Feb 24 05:06:42 MST 2015
LPC_PINCON->PINMODE4 = 1 << 5; //enable P2.2,MR3 neither pull up nor pull down.
LPC_PINCON->PINMODE4 = 1 << 3; //enable P2.1,MR2 neither pull up nor pull down.
Of course that's nonsense, you are setting your registers twice, deleting the last setting  ;-)
995件の閲覧回数
lpcware
Content originally posted in LPCWare by Wilbur He on Tue Feb 24 05:06:25 MST 2015
I am so Sorry that I  just learnt LPC programming last week, do you know the problem? can you tell me? Thank you very much!!!
995件の閲覧回数
lpcware
Content originally posted in LPCWare by R2D2 on Tue Feb 24 05:04:04 MST 2015
Quote: Wilbur He
Can anyone help me? I am waiting online now
Don't wait, read a C book...
995件の閲覧回数
lpcware
Content originally posted in LPCWare by Wilbur He on Tue Feb 24 05:02:51 MST 2015
