LPC1765 flash retention time
754件の閲覧回数
davidouatt08
I need to estimate the flash retention time for an LPC1765 constantly powered under a temperature of 40°C.
In the Reference Manual, the retention time for a powered device is 10 years min and 20years min for an unpowered device, but I look for a more precise estimation for a running without interruption at 40°C.
Support is much appreciated
741件の閲覧回数
vicentegomez
If the devices are using under all the specifications. those can support the 10 years at 40C, as you can see on the datasheet, this spec is from Tamb = −40 °C to +85 °C.
You need to be sure while you are running at 40C continuously all the other specs are under spec, also the power consumption, read and write on memories, etc.
I hope this will help you
Have a good day.
742件の閲覧回数
vicentegomez
Have a good day.
