LPC 804 deep power down wakeup is not working
RDGC_member
We need to use the deep power down mode in our product.
we are successful to put the uc in deep power down mode , also initialized pin PIO0_11 for wake up from deep power down mode .but uc is not waking up. what may be the reason for it .
ZhangJennie
Hi RDGC_member
Please note for Deep power-down mode, All clocks, the core, and all peripherals are powered down. Only the WAKEUP pins are powered. All functional pins are tri-stated in deep power-down mode except for the WAKEUP pin.
Please use WAKEUP pin wake up LPC804 from deep power down mode.
There is power_mode_switch_lpc demo code under MCUXpresso SDK folder, I suggest you referring it for the low power usage.
Jun Zhang
