Issue openning ISPMODE from NXPDEBUGMBOX on LPC55S06
927件の閲覧回数
Aurelien_Grange
I correctly configure my LPC55S06 to use secure boot and Debug Authentication.
I have an issue I can't go to ISP mode from "nxpdebugmbox ispmode -m 0" command.
How can i do that?
Can i allow this command only for  people with correct credential (as defined by AN13037)?
Thanks for helping me
4 返答(返信)
917件の閲覧回数
This is a known issue, the debug mailbox command "Enter ISP mode" doesn't work.
Our SE team  has asked internal team to  fixed this issue.
Alice
903件の閲覧回数
Aurelien_Grange
Hi thanks for your quick answer, have you got some timelines about the end of this issue?
875件の閲覧回数
Hello ,
Below is information from SE, you can refer to:
The root cause is the command should use "-n" parameter.
The tool always exits from debug mailbox after successful authentication when “--no-exit” parameter is not used. But when you need to execute “enter ISP” command, you should not exit the mailbox to remain in authenticated state.
nxpdebugmbox -p 1.0 auth -b 0 -c dck.dc -k dck.pem -n
Also, need "-n" for "Enter ISP Mode", this avoid the reset and keep the debug permission.
nxpdebugmbox -n -p 1.0 ispmode -m 1
Alice
890件の閲覧回数
Hello ,
It seems the old silicon doesn't support it. Please  get date code on the part, send it to me.
Alice
