I'm using LPC11A14. The pull-up fail when I configure the main source clock
951 次查看
henryfabriciopi
In the LPC11A14, I need to use the on chip pull-up resistor on my GPIO P0_28 as input port. It works good. But it fail when I configure de PLL output as my main clock source.
MAINCLKUEN_bit.ENA = 0; // in this point the pull-up is working very good!
MAINCLKSEL_bit.SEL = 3; // in this point the pull-up is working very good!
MAINCLKUEN_bit.ENA = 1; // after execution of this code, the pull-up is no more working.
To see the pull-up active, I used a voltmeter in the P0_28 pin. When it is working, I see 2,8V (I expected 3,3V, but with 2,8V is working). But when it is not working, I see 0,6V in this pin.
I used the function InitClock to configure the main clock and the PLL. If I change the divisor (second parameter), the voltage in the pin changes too.
For more informations, my complete code is:
void main(void)
  //GPIO configuration:
  P0DIR_bit.DIR28=0;
  IOCON_P0_28_bit.FUNC=0;
  IOCON_P0_28_bit.MODE=2;
  //Configuration of clock
  InitClock(240MHZ, 5); //<<< PROBLEM INSIDE THIS FUNCTION
  while(true)  {    /* my code */   }
void InitClock(Int32U pllclock, Int32U ahbdiv) //page. 27
  /* Enable XTAL Oscilator */
  PDRUNCFG_bit.XTAL_PD = 0;
  /* Enable Internal RC oscilator */
  PDRUNCFG_bit.IRC_PD = 0;
  /* Select internal RC oscilator for SYS clock source */
  MAINCLKSEL_bit.SEL = 0;
  /* Configure System PLL */
  /* Power-down System PLL */
  PDRUNCFG_bit.SYSPLL_PD = 1;
  /* Select XTAL Oscilator for SYS PLL input */
  SYSPLLCLKUEN_bit.ENA = 0;
  SYSPLLCLKSEL_bit.SEL = 0;     //0=IRC,  1=XTAL,  2=CLKIN pin
  SYSPLLCLKUEN_bit.ENA = 1;
  /* Calculate M */
  Int32U m = pllclock/(XTAL_OSC_FREQ*(2*2)) - 1;
  assert(m<32);
  /* Configure PLL frequency */
  SYSPLLCTRL_bit.MSEL = m;
  SYSPLLCTRL_bit.PSEL = 1;
  /* Power-up PLL */
  PDRUNCFG_bit.SYSPLL_PD = 0;
  /* Set System AHB Clock divider */
  SYSAHBCLKDIV_bit.DIV = ahbdiv;
  /* Wait until PLL locks */
  while(!(SYSPLLSTAT_bit.LOCK));
  /* Select System PLL Output for SYS clock source */   //page. 20
  MAINCLKUEN_bit.ENA = 1;  //<<< PROBLEM AFTER THIS EXECUTION
标记 (1)
664 次查看
henryfabriciopi
I found the solution. I changed the microcontroler and now is working.
Thanks for all.
Henry
665 次查看
henryfabriciopi
Thanks for all.
Henry
664 次查看
DavidS
Hi Henry,
Sorry I don't have a board to try and test.
One question.  Did you enable the SYSAHBCLKCTRL[IOCON] block clock?
David
664 次查看
henryfabriciopi
Yes, I do it in my code:
  /* Enable GPIO Clock */
  SYSAHBCLKCTRL_bit.GPIO = 1;
  /* Enable IOCON Clock */
  SYSAHBCLKCTRL_bit.IOCON = 1;
