Hi Archana Ravindran,
P0.27 and P0.28 is the true open-drain pin.
So, please add external pullup up in these two pins, then try again.
Wish it helps you!
If you still have question about it, please let me know!
Kerry
What the problems you are meeting now?
Check the pin waveform with the oscilloscope, whether the wave in these two pin is correct?
If the pin wave is correct, you need to check your software code which communicate with your LCD, it should meet the LCD command demand.
Kerry
