How to setup a pin as interrupt source and then call user defined callback function?
1,392 次查看
misterbee
I am using LPC 54113 MCU. I want to use the config tool. Suppose I have a pin PIO0_1 initially at high. When it goes low, I want it to raise interrupt and then call my defined callback function say my_callback().
How can I achieve this? How should I do the configuration?
标签 (1)
1 回复
1,370 次查看
Pavel_Hernandez
I suggest downloading the SDK of the LPCxpresso54114 and reviewing the example lpcxpresso54114_pint_pin_interrupt then you can port it to your target.
Pavel
