Graphic distortion when accessing SRAM?
498件の閲覧回数
lpcware
Content originally posted in LPCWare by tjoAG on Tue Aug 07 22:39:34 MST 2012
Hi All
I'm using a LPC1788 at 120 MHz, with a 16 bit SDRAM and 16 bit SRAM
The frame buffer is located in the SDRAM and I use the SRAM for some persistent data.
When I access the SRAM with relative large memory amount (+300 bytes memcpy), the display has graphics distortion. It looks like it draws shadows of the text displayed.
I guess the EMC is busy accessing the SRAM and the LCD DMA transfer is blocked.
I could split my SRAM access into smaller pieces or use DMA access to the SRAM.
That may help?
Speed up SRAM/SDRAM timing?
But is there any other solutions or am I just doing things wrong.
I'm using FreeRTOS.
Thomas
0 返答(返信)
