Generate 4 Pulses with SCT without interrupt
817 次查看
sodiptaberutu
Hallo all,
I try to generate 4 Pulse with SCT on LPC 1549 (see on the attachment). I use it for burst the ultrasonic sensor.  My question is: how can I generate the pulses without an Interrupt Routine. Any ideas?
Thank you
Sodipta Karina
标签 (2)
标记 (2)
632 次查看
sodiptaberutu
I have read it and it helps me. I have 1 question namely: For example I use SCT0, then I divide it into SCT0_High and SCT0_Low. Are those Timers (SCT0_H and SCT0_L) be able to start counting at the same time?
Sodipta
632 次查看
jeremyzhou
Hi Sodipta,
Yes, SCT0_H and SCT0_L value can start increase at the same time, about the run the SCT, you can learn the more information in the section Run the SCT in the reference manual.
Hope it helps.
Ping
632 次查看
jeremyzhou
I've attached the application demo about the SCTimer, and please refer to it for details.
www.nxp.com/documents/application_note/AN11538.zip?fasp=1&WT_TYPE=Application%20Notes&WT_VENDOR=FREE...
Ping
