Hi all,
I'm new to LPC and need some help. I wanna set up a Timer triggered DMA transfer to transfer data from pin to a defined adress in the SRAM1. Every time the MR0 matches the DMA transfer should start. I work with the LPC4088 Quickstart Board. I set the Board up to run at 120MHz. My Peripherals also run at 120MHz. I studied the UM and wrote some code but when I compile nothing happens. The timer works fine and I see a 10MHz output on the defined pin.
I attached my simple code I wrote extra for this.
Hope anyone of you can help me.
Best Tim
#include "LPC407x_8x_177x_8x.h"
#define PERIPHSRAM1 0x20004000
char adcData[11] = {1,1,1,1,1,1,1,1,1,1,1};
volatile uint32_t DMATCCOUNT = 0;
volatile uint32_t DMAERRCOUNT = 0;
void DMA_IRQHandler(){
uint32_t temp;
DMATCCOUNT++;
temp = LPC_GPDMA->IntTCStat;
if(temp){
DMATCCOUNT++;
LPC_GPDMA->IntTCClear |= temp;
temp = LPC_GPDMA->IntErrStat;
if(temp){
DMAERRCOUNT++;
LPC_GPDMA->IntErrClr |= temp;
return;
int main(){
uint8_t size = sizeof(adcData);
LPC_SC->PCONP |= (1 << 22); //Power & Clock Timer 2
LPC_TIM2->CTCR = (0 << 0); //Timer Mode
LPC_TIM2->PR = 0;
LPC_TIM2->TCR = (1 << 1); //Reset timer
LPC_TIM2->TC = 0;
LPC_TIM2->MR0 = 5; //Match register to get 10MHz
LPC_TIM2->MCR = (1 << 1) //Reset Timer
|(1 << 0); //Interrupt if MR matches
LPC_TIM2->EMR = 0x31; //toggle pin to check wave output
LPC_TIM2->TCR = (1 << 1); //reset timer again
LPC_SC->PCONP |= (1 << 29); //Power & Clock DMA
LPC_GPDMACH0->CConfig = 0; //disable CH0
LPC_GPDMA->Config |= (1 << 0); //enable DMA Controller
LPC_SC->DMAREQSEL = 0x010; //Set T2 MAT0 as DMA request
LPC_GPDMA->IntErrClr |= 0x0FF;
LPC_GPDMA->IntTCClear |= 0x0FF;
LPC_GPDMACH0->CDestAddr = PERIPHSRAM1;
LPC_GPDMACH0->CSrcAddr = (uint32_t) &adcData;
LPC_GPDMACH0->CControl = size
|(0x03 << 12) //Source Burst size: 16 (16bit?)
|(0x03 << 15) //Destination Burst size: 16
|(0x01 << 18) //Source width: 16 bit
|(0x01 << 21) //Destination width:16 bit
|(0x01 << 26) //Source increment: enabled
|(0x01 << 27) //Destination increment: enabled
|(0x01 << 31); //Terminal Count interrupt enabled
LPC_GPDMACH0->CControl |= (4 << 1) //Source peripheral: Timer2 MR0
|(0 << 11); //Memory to memory trasnfer
NVIC_SetVector(DMA_IRQn, (uint32_t) DMA_IRQHandler);
NVIC_EnableIRQ(DMA_IRQn);
LPC_GPDMACH0->CConfig |= 1; //Enable channel
LPC_TIM2->IR |= 0x0FF; //CLear all timer interrupts
LPC_TIM2->TCR = 0x01; //start Timer
while(!DMATCCOUNT); //Wait till transfer Complete
while(1){
Hello Tim Krebs,
About "when I compile nothing happens.", could you describe this more detail please.
I recommend you check module by module, for example, use software start DMA, check it can work well,
then use Timer trigger DMA.
Alice
Hi Alice,
I got it working. The failure was, that I wanted to do a transfer from RAM to RAM, but that does not work with DMA. So I started to setup a transfer directly from the pins and now everything works as it should.
Best
Tim
