I want to switch to the LPC812 for my project but I need some bytes of non-volatile memory.
Is it possible to emulate an EEPROM memory with the embedded flash memory? If so, is there any sample code for doing this?
Is it possible to replace some variables with the IAP?. I want to uptdate some variables after the program is executed and the user changes some parameters, those variables have to be updated the next time the program executes.
Thanks a lot, I'll check that
