Difference between debug, release builds
338 次查看
YaronAlexandrovich
Contributor V
There are four scenarios:
Run a debug session using the 'PE Debug' build
Run a board that has been flashed with a 'PE Debug' build, not in debugger
Run a debug session using the 'PE Release' build
Run a board that has been flashed with a 'PE Release' build, not in debugger
I know RTFM is the right answer here, but I would appreciate a brief explanation of what is occurring in each of these 4 scenarios, as each leads to different behaviors.
Also, to prove code correctness, I assume the code should work properly under a 'PE Release' non-debug session.  As of now only a 'PE Debug' debug session works correctly.
314 次查看
Hello @YaronAlexandrovich
Do you mean MCUXpresso IDE? If yes, please see <MCUXpresso_IDE_User_Guide.pdf>
MCUXpresso IDE creates projects with two build configurations, Debug and Release (but you can also add more if required). These differ in the default level of compiler optimization.
Debug projects default to None (-O0), and Release projects default to (-Os). For more information
on switching between build configurations, see How do I switch between Debug and Release
builds?
Alice
315 次查看
builds?
Alice
