Coridium SuperPro+ BASIC Compiler
334 次查看
lpcware
Content originally posted in LPCWare by dgarofolo on Tue Jul 17 06:03:08 MST 2012
I am trying to connect a quadrature (rotory) encoder to my Coridium SuperPro+ board, using their free BASICtools compiler. It needs to run on a timed interrupt to ensure an adequate polling rate. I can't figure out how to get the interrupts to work as explained in the help files. Does anyone have any experience with this BASIC compiler? Below is my test code. I would expect that every second it would print a higher value for X. I get zeros, so the Interrupt Sub must not be running? Any suggestions or sample code would be greatly appreciated.
DIM X As Integer
INTERRUPT SUB every20msec:
X = X + 1
ENDSUB
main:
ON TIMER 20 every20msec
PRINT "DO SOME OTHER STUFF TOO"
PRINT X
Wait (1000)
GOTO Main
END
304 次查看
lpcware
Content originally posted in LPCWare by cfbsoftware on Sat Jul 28 18:04:52 MST 2012
This question has been answered in the Yahoo ARMExpress group:
http://tech.groups.yahoo.com/group/ARMexpress/message/3280
