emWin支持哪些编译器/IDE?
emWin支持哪些编译器/IDE?
lpcware-support
Senior Contributor I
恩智浦在LPCware.com上有ARM/Keil, IAR, Rowley Crossworks和LPCXpresso的安装包。如有需要,以后会添加对其他编译器的支持。
Lambert
HI Lpcware_Support,
My csutomer is using I.MX7D(CotexA7+M4) on their project, and they are running FreeRTOS on M4. they are planning to  port emWin on FreeRTOS running with M4,  and they are using
GCC revision 4.9-2015-q1-update from ARM Embedded
cross-compiler to compile FreeRTOS, is it possible to provide emWin lib which generated by GCC revision 4.9-2015-q1-update from ARM Embedded to customer?  Pls comment.
Lambert
