trouble reading uart
745件の閲覧回数
josephgundel
I have 2 UARTs I am using on the K02 Board I have.
One is set up for DEBUG and it works normal. I can Use Interrupts no problem.
When I configure the 2nd UART, UART1 I cannot read anything out of the port. I cannot use Interrupts as well.
Here is my configuration:
/*! User configuration structure 0 */
/*! fsl_uart1 configuration structure */
const uart_user_config_t fsl_uart1_InitConfig0 = {
    .baudRate = 115228U,
    .parityMode = kUartParityDisabled,
    .stopBitCount = kUartOneStopBit,
    .bitCountPerChar = kUart8BitsPerChar,
static uart_status_t uart1_init(void)
    uart_status_t status = UART_DRV_Init(FSL_FSL_UART1, &uart1_state, &fsl_uart1_InitConfig0);
    UART_HAL_SetIntMode(g_uartBaseAddr[FSL_FSL_UART1],kUartIntRxDataRegFull,true);
    return status;
I have tried reading using blocking and also using an Interrupt and It never reads anything. I can transmit out no problem but I cannot read.
I know it is not a hardware issue because when i switch this port to the debug instance it works correctly. Something must be configuring it differrently when used as Debug.
Please Help!!!
タグ(2)
3 返答(返信)
506件の閲覧回数
ivadorazinova
Hello Joseph,
please, where do you have any array for received characters?
Can you attach whole project?
Iva
506件の閲覧回数
josephgundel
I cannot post the whole project > I am trying to just read one character at a time or call the ISR. It does not do either
506件の閲覧回数
ivadorazinova
Hello Joseph,
never mind, please just send me part of the code where you work with uart.
I mean pin settings on UART, UART settings, interrupts...
Thank you.
Iva
