What does a blocking peripheral driver actually block?
1,243件の閲覧回数
althafismail
I'm trying to optimize the timing in my application that uses the K64F12, KDS3.0, KSDK1.3, and MQX.  I wonder if any one know if a blocking peripheral driver only blocks the corresponding MQX task that calls it, or does it completely block MQX from continuing on with other tasks?
タグ(1)
1,170件の閲覧回数
xiangjun_rong
Hi, Althaf,
As far as I know, most peripheral drivers of MQX do not use blocking mechanism, in other words, the read()/write() function return immediately without blocking. If the peripheral drivers use blocking mechanism, it only blocks the corresponding MQX task that calls it.
Hope it can help you.
Xiangjun Rong
