TPM with RTC Seconds as trigger
870 次查看
aescov
I am trying to the use the TPM as capture timer with RTC seconds as trigger on the K65
I have the TPM counter running and the RTC generates 1 second interrupts.
TPM input clock is OSCER.
TPM trigger is set to RTC Seconds (13) but i do not get any TPM channel interrupt.
However I do get TPM overflow interrupts which indicates that the TPM counter is running. Also I can see the count value changing.
My setup code look like this
       CLOCK_SetTpmClock(2);
        // Start Capture timer
        tpm_config_t config;
        TPM_GetDefaultConfig(&config);
        config.prescale = kTPM_Prescale_Divide_1;
        config.useGlobalTimeBase = false;          /* Use internal TPM counter as timebase */
        config.enableDoze = false;                 /* TPM counter continues in doze mode */
        config.enableDebugMode = false;            /* TPM counter pauses when in debug mode */
        config.enableReloadOnTrigger = false;      /* TPM counter will not be reloaded on input trigger */
        config.enableStopOnOverflow = false;       /* TPM counter continues running after overflow */
        config.enableStartOnTrigger = false;        /* TPM counter starts on first trigger */
        config.enablePauseOnTrigger = false;       /* TPM does not pause on trigger */
        config.triggerSelect = kTPM_Trigger_Select_13;        /* Choose trigger select 0 as input trigger for controlling counter operation */
        config.triggerSource = kTPM_TriggerSource_External;   /* Choose external trigger source to control counter operation */
        TPM_Init(TPM1, &config);
        // Enable overflow interrupt
        TPM_EnableInterrupts(TPM1, kTPM_Chnl0InterruptEnable | kTPM_TimeOverflowInterruptEnable);
        NVIC_SetPriority(TPM1_IRQn, TPM1_INTERRUPT_PRIORITY);
        NVIC_EnableIRQ(TPM1_IRQn);
        TPM1->CNT = 0x0;
        TPM1->MOD = 0xFFFF;
        // Clear overflow flag
        TPM1->SC |= TPM_SC_TOF_MASK;
        TPM_SetupInputCapture(TPM1,kTPM_Chnl_0, kTPM_RisingEdge);
        TPM_StartTimer(TPM1, kTPM_SystemClock);
Have anyone of you tried this configuration with success.
Any suggestions appreciated.
Anders
450 次查看
xiangjun_rong
It seems that you have to add the line:
NVIC_ClearPendingIRQ(TPM1_IRQn);
You have to replace the interrupt vector table with your own ISR.
If you still have issue, pls upload your project so that your code can be debugged.
Hope it can help you.
Xiangjun Rong
