Sending data from ethernet in FRDMK64F?
730 次查看
mehmetak
I have FRDK64F microcontroller. I would like to send a data from ethernet when I get the data from RS485. how can I do? Is there sample code or sending data from ethernet? Also, is my rs 485 code correct?
My rs485 code is here;
uint8_t command_t,command_2_1,command_2_2,command_2_3,byte0,byte1,byte2,byte3;
uint8_t receiveState=0;
uint8_t byteCounter=0;
uint8_t command=0;
uint8_t dataLength=0;
uint8_t checksum=0;
uint8_t calculatedChecksum;
uint8_t messageReceivedFlag=0;
uint8_t addresAndMessageType=0;
uint8_t sourceAddress[3];
uint8_t destinationAddress[3];
uint8_t receiveBuffer[50];
int main(void)
    uart_config_t config;
    BOARD_InitPins();
    BOARD_BootClockRUN();
     * config.baudRate_Bps = 115200U;
     * config.parityMode = kUART_ParityDisabled;
     * config.stopBitCount = kUART_OneStopBit;
     * config.txFifoWatermark = 0;
     * config.rxFifoWatermark = 1;
     * config.enableTx = false;
     * config.enableRx = false;
    UART_GetDefaultConfig(&config);
    config.baudRate_Bps = BOARD_DEBUG_UART_BAUDRATE;
    config.enableTx = true;
    config.enableRx = true;
    UART_Init(DEMO_UART, &config, CLOCK_GetFreq(DEMO_UART_CLKSRC));
    /* Send g_tipString out. */
    UART_WriteBlocking(DEMO_UART, g_tipString, sizeof(g_tipString) / sizeof(g_tipString[0]));
    /* Enable RX interrupt. */
    UART_EnableInterrupts(DEMO_UART, kUART_RxDataRegFullInterruptEnable | kUART_RxOverrunInterruptEnable);
    EnableIRQ(DEMO_UART_IRQn);
    while (1)
  if(messageReceivedFlag) // Ben ekledimm.
  command_t=command;
  command_2_1 = receiveBuffer[0];
  command_2_2 = receiveBuffer[1];
  command_2_3 = receiveBuffer[2];
  byte0 = receiveBuffer[3];
  byte1 = receiveBuffer[4];
  byte2 = receiveBuffer[5];
  byte3 = receiveBuffer[6];
  if(command_t==0xf4 && command_2_1==0x52 && command_2_2==0x42 && command_2_3==0x53)
void DEMO_UART_IRQHandler(void)
    uint8_t data;
    /* If new data arrived. */
    if ((kUART_RxDataRegFullFlag | kUART_RxOverrunFlag) & UART_GetStatusFlags(DEMO_UART))
        data = UART_ReadByte(DEMO_UART);
        switch(receiveState)
            case 0:
                if(data==0x00)        // local address and message type(2) check
                   calculatedChecksum=0;
                   receiveState=1;
            break;
            case 1:         // Get source address
                sourceAddress[byteCounter++]=data;
                calculatedChecksum += data;
                if(byteCounter==3)
                   receiveState=2;
                   byteCounter=0;
            break;
            case 2:          // Get destination address
                destinationAddress[byteCounter++]=data;
                if(byteCounter==3)
                   receiveState=3;
                   byteCounter=0;
            break;
            case 3:     // Get command
                command=data;
                receiveState=4;
            break;
            case 4:     // Get packet lentgh
                dataLength=data;
                byteCounter=0;
                receiveState=5;
            break;
            case 5:     // Get rest of the packet
            receiveBuffer[byteCounter++]=data;
                if(byteCounter==dataLength)
                    receiveState=6;
            break;
            case 6:     // Get checksum and check it
                checksum=data;
                if(calculatedChecksum == 0xff)
                    messageReceivedFlag=1;
                receiveState=0;
            break;
342 次查看
xiangjun_rong
Hi, Mehmet,
Regarding your  question, I suggest you download the SDK2.0 for FRDM-K64F from the website:
Welcome to Kinetis Expert | Kinetis Expert
After you download SDK2.0, you can find the lwip example code located at the directory:
C:\DriverE\Freescale\SDK2.0_K64F\boards\frdmk64f\demo_apps\lwip
We have echo example for both UDP and TCP protocol, if you use the K64 ethernet in client mode, I suppose you have to change the code, because the example is in server mode.
Regarding RS232, we have the UART driver located at :
C:\DriverE\Freescale\SDK2.0_K64F\boards\frdmk64f\driver_examples\uart
Regarding your UART code, I think it is okay.
XiangJun Rong
