SAI/I2S Driver for the KL27Z
1,518件の閲覧回数
andrewdeliso
I am attempting to build an audio application using the I2S bus on the FRDM-KL27Z board.  The KSDK v2.0 doesn't have a driver for the SAI/I2S bus other that the flexIO.  Is one planned?  Or is it not supported?
Thanks.
989件の閲覧回数
andrewdeliso
Hi Xiangjun,
I got this table from the rep.  It explains the differences.  I have started the process of porting the sai drivers to the KLK27Z.
The KL27Z devices in red below with 128K or 256K of Flash include one I2S port.  The 32K/64K Flash devices do not.
MK Part Number
Total Flash Memory (KB)
SRAM (KB)
Pin Count
Package
I2S
MKL27Z32VDA4
32
8
36
XFBGA
MKL27Z32VFM4
32
8
32
QFN
MKL27Z32VFT4
32
8
48
QFN
MKL27Z32VLH4
32
8
64
LQFP
MKL27Z32VMP4
32
8
64
MAPBGA
MKL27Z64VDA4
64
16
36
XFBGA
MKL27Z64VFM4
64
16
32
QFN
MKL27Z64VFT4
64
16
48
QFN
MKL27Z64VLH4
64
16
64
LQFP
MKL27Z64VMP4
64
16
64
MAPBGA
MKL27Z128VFM4
128
32
32
QFN
1
MKL27Z128VFT4
128
32
48
QFN
1
MKL27Z128VLH4
128
32
64
LQFP
1
MKL27Z128VMP4
128
32
64
MAPBGA
1
MKL27Z256VFM4
256
32
32
QFN
1
MKL27Z256VFT4
256
32
48
QFN
1
MKL27Z256VLH4
256
32
64
LQFP
1
MKL27Z256VMP4
256
32
64
MAPBGA
1
9 返答(返信)
989件の閲覧回数
andrewdeliso
If its not there, why do the data sheets and reference manual have that component?  I am already into prototype run of boards so changing parts is not an option.
989件の閲覧回数
xiangjunrong
Hi, Andrew,
I have downloaded the reference Manual, I read the RM carefully, but I do not see there is I2S or SAI module, I do not see the pin assignment for the I2S module in the Chapter 10 Pinouts and Packaging in the KL27P64M48SF2RM.pdf file. But the diagram of KL27Z  on the website does show that there is I2S module, I am also confused.
can you tell me the Reference manual you referred to? which pins are I2S pins for example bit clock/frame clock/data pins for both receiver and transmitter in your RM?
The Kl27 do have FlexIO which can simulate the I2S timing, but we do not discuss the case.
I am sorry if I am wrong.
Xiangjun Rong
989件の閲覧回数
andrewdeliso
Hi Xiangjun Rong,
On Rev. 5 of the datasheet:
And in 01/2016 version of the reference manual:
989件の閲覧回数
xiangjunrong
Hi, Andrew,
I apologize for the wrong information, the Kl27Z does have SAI module. I have downloaded the latest revision 5 of Reference manual of KL27, it says that Kl27 has SAI module exactly. But the revision 3 of reference manual of Kl27 I had does not mention any SAI module. I suspect that is why the software  team does not develop code for the SAI module.
Regarding the driver of SAI, I think you can download the SAI driver from the other chip for example Kl33/kl36, and copy the fsl_sai.c and fsl_sai.h code to the C:\Freescale\KSDK2.0_KL27\devices\MKL27Z644\drivers, it is okay.
Hope it can help you.
Xiangjun Rong
990件の閲覧回数
andrewdeliso
Hi Xiangjun,
MK Part Number
SRAM (KB)
Pin Count
Package
I2S
MKL27Z32VDA4
32
8
36
XFBGA
MKL27Z32VFM4
32
8
32
QFN
MKL27Z32VFT4
32
8
48
QFN
MKL27Z32VLH4
32
8
64
LQFP
MKL27Z32VMP4
32
8
64
MAPBGA
MKL27Z64VDA4
64
16
36
XFBGA
MKL27Z64VFM4
64
16
32
QFN
MKL27Z64VFT4
64
16
48
QFN
MKL27Z64VLH4
64
16
64
LQFP
MKL27Z64VMP4
64
16
64
MAPBGA
MKL27Z128VFM4
128
32
32
QFN
1
MKL27Z128VFT4
128
32
48
QFN
1
MKL27Z128VLH4
128
32
64
LQFP
1
MKL27Z128VMP4
128
32
64
MAPBGA
1
MKL27Z256VFM4
256
32
32
QFN
1
MKL27Z256VFT4
256
32
48
QFN
1
MKL27Z256VLH4
256
32
64
LQFP
1
MKL27Z256VMP4
256
32
64
MAPBGA
1
989件の閲覧回数
xiangjunrong
Hi, Andrew,
Thank you for providing the table and tell me the information that only Kl27Z with 128/256K flash has I2S interface.
Xiangjun Rong
989件の閲覧回数
Hello Andrew,
If the ksdk2.0 have not the SAI driver, you can use the KSDK1.3,
it have "fsl_sai"
pastedImage_0.pngf
Hope it helps
Alice
989件の閲覧回数
andrewdeliso
Hi Alice,
I looked at the v1.3 SDK.  Is there a plan to port this driver to 2.0?  Also the 1.3 SDK has a feature count of 0, has this driver been tested on this platform?
./platform/devices/MKL27Z644/include/MKL27Z644_features.h:224:#define FSL_FEATURE_SOC_I2S_COUNT (0)
989件の閲覧回数
xiangjunrong
Hi, Andrew,
It seems that the KL27 does not have SAI peripheral, that is why that the SDK2.0 of KL27 does not include the SAI driver. But the Kl27 has flexIO, it is said that it can simulate the SAI timing, but I do not know the performance.
can you select the other Kinetis processor which has SAI module for example Kinetis K family?
Xiangjun Rong
