KDS project destroyed
610件の閲覧回数
pietrodicastri
Senior Contributor II
Good morning,
I had a running project. Suddenly I get this message. It seems some configuration has gone destroyed.
Is there a suggestion  how to repair the project, without rebuilding a new one???
Thank You
18:56:00 **** Incremental Build of configuration Debug for project CapasBootloader003 ****
make all
'Building file: ../Sources/SDK/fsl_adc16.c'
'Invoking: Cross ARM C Compiler'
arm-none-eabi-gcc -mcpu=cortex-m4 -mthumb -mfloat-abi=hard -mfpu=fpv4-sp-d16 -Os -fmessage-length=0 -fsigned-char -ffunction-sections -fdata-sections  -g3 -DCPU_MK64FN1M0VMD12 -DFOR_MAIN_BOARD = 1 -DNDEBUG -I"../Sources" -I"C:\PietroWorks\KDSProjects\CapasBootloader003\Sources\FS" -I"C:\PietroWorks\KDSProjects\CapasBootloader003\Sources\Console" -I"C:\PietroWorks\KDSProjects\CapasBootloader003\FlashDrv" -I"C:\PietroWorks\KDSProjects\CapasBootloader003\Includes" -I"C:\PietroWorks\KDSProjects\CapasBootloader003\Sources\SDK" -I"C:\PietroWorks\KDSProjects\CapasBootloader003\Sources\Includes" -I"C:\PietroWorks\KDSProjects\CapasBootloader003\Includes" -I"../Includes" -std=c99 -MMD -MP -MF"Sources/SDK/fsl_adc16.d" -MT"Sources/SDK/fsl_adc16.o" -c -o "Sources/SDK/fsl_adc16.o" "../Sources/SDK/fsl_adc16.c"
arm-none-eabi-gcc: error: =: No such file or directory
arm-none-eabi-gcc: error: 1: No such file or directory
make: *** [Sources/SDK/fsl_adc16.o] Error 1
18:56:02 Build Finished (took 1s.458ms)
タグ(1)
447件の閲覧回数
BlackNight
Hi Pietro,
your problem is that you use
it should be
-DFOR_MAIN_BOARD=1
(without the spaces)
I hope this helps,
Erich
4 返答(返信)
448件の閲覧回数
BlackNight
Hi Pietro,
it should be
-DFOR_MAIN_BOARD=1
I hope this helps,
Erich
447件の閲覧回数
pietrodicastri
Hi Erich
You are right..
It works now,,,,
Thank You
P.S.
I don t find the way to tag the answer as correct... Suggestions?
447件の閲覧回数
ivadorazinova
Hi Pietro,
you created a discussion, no question and this is the reason why there was not correct answer button.
I  converted the discussion to question. Now you should be able to mark Erich Styger´s answer as correct answer.
Iva
447件の閲覧回数
pietrodicastri
Yes
Thank You
