I want to store some constant values to EEPROM. But the datasheet says frdm-kw41z has only 512 KB flash, 128 KB SRAM. No details about EEPROM. How to store these constant values in internal flash without affecting the code. If is there any example code please attach here.
Thanks in advance.
Could you please check the BLE Application Developer's Guide? There you will find more details regarding the storage in the EEPROM , NVM, etc.
The file can be found in the SDK documentation C:\<installation path>\docs\wireless\Bluetooth
Estephania
