i'm using nxpMClib_v1.0_0 library for PMSM motors, but is there any description about that example code?
best regards,
pouya
Hi, Pouya,
You can download the library of motor control from the link:
Real Time Control Embedded Software Motor Control and Power Conversion Libraries|NXP
After you install the library, you can read the pdf file which describes every function in detail.
C:\Freescale\FSLESL\doc\56800EX_FSLESL_4.2_doc
Regarding the PMSM FOC control basic theory, pls refer to the an1931 from the link:
https://www.nxp.com/docs/en/application-note/AN1931.pdf
Hope it can help you
Xiangjun Rong
