kinetis frdm-k22f printf redirection
861件の閲覧回数
shkim9
when i download kinetis sdk (via sdk generator), there is demo apps.
and default printf function in demo app's output is directed to UART1.
i want to redirect printf function to SWO output (j-link). but i can't find it.
MCUXpresso configtool has no SWO feature (peripherals)
and also SDK generator does not have it.
so, for redirect printf output to SWO,
Is there a way to generate code using the tool (MCUXpresso, SDK generator, .... ) ?
or is there any sample project using SWO ?
** IDE : IAR embedded workbench
** Debugger : J-Link SWD connection
** target board : FRDM-K22F
ラベル(2)
3 返答(返信)
712件の閲覧回数
shkim9
SWO pin not connected.
i think if this pin is connected, it may be operate.
j-link connector
FRDM-K22F connector
712件の閲覧回数
BlackNight
That very much depends on your standard I/O library implementation.
I'm using MCUXpresso IDE 10.3.1 and it has an option to redirect printf() to SWO, see section "SWO (Single Wire Output" in New NXP MCUXpresso IDE V10.3.0 Release | MCU on Eclipse.
For IAR you could copy that code or you might use the code snippets from Tutorial: Using Single Wire Output SWO with ARM Cortex-M and Eclipse | MCU on Eclipse .
I hope this helps,
Erich
712件の閲覧回数
shkim9
thanks Erich Styger.
i try build project on MCUXpresso IDE.
as you mentioned, check redirect option and create new project.
(but, there is no "SWO" related options)
and printf still not work.
i think the macro defined in "serial_manager.h" is wrong.
"SERIAL_PORT_TYPE_SWO" should be "1".
but if i change this value to "1" (and "SERIAL_PORT_TYPE_UART" are "0" ), build error occurs.
fatal error: serial_port_swo.h: No such file or directory
i can't find "serial_port_swo.h" anywhere.
it seems to be generated by MCUXpresso IDE.
Is there a better way?
** additionally, Kinetis SDK has no "serial_port_swo.h" file.
The figure below shows the sdk directory. There is no "serial_port_swo.h".
thanks.
