k64 usb err
k64 usb err
580件の閲覧回数
dugg
hello everyone
      during the communication of the USB,i pull up the USB line, the routine enter into the interrupt of usb err.
      but,i read the register of USB0_ERRSTAT,it's value is 0x00,
      how can i know  the reason of the err?
418件の閲覧回数
Sabina_Bruce
In order to understand the results from the those registers I recommend that you take a look at the Reference Manual and sections 46.4.9, 46.4.10 and 46.4.11. These sections explain the bits in those registers, normally a 0x00 is read after a reset.
In addition, if you are working with USB I would also recommend that you take a look at SDK examples that focus on USB for the K64, as a reference.
Let me know if you have questions with the above mentioned,
Thank you,
Sabina
