eGUI
eGUI
1,113件の閲覧回数
Etienne
hello
i'm doing an application from scratch on egui.
I have 3 icons and i would like to navigate sequentially on them with 3 buttons (LEFT, OK, RIGHT).
today, i'm able to catch button events (LEFT, OK, RIGHT) but impossible to change the focus to redirect event to the 2 others.
D4D_OBJECT_F_TABSTOP option is correctly set in the ICON declaration.
D4D_FocusSet(screen,object) seems to don't work
do you please have an example where you are succesfully navigating between objects ?
thank you.
best regards
Etienne
タグ(3)
2 返答(返信)
747件の閲覧回数
Ali_Pina
Hi Etienne,
I developed an example using the on-board switches in the TWR-K70, this project was developed in CW 10.3 and using MQX 4.0.
I based most of the example on the thread discussion:
https://community.freescale.com/message/93504#93504
SW1 is used to navigate between two text buttons and SW2 is used as the ENTER button.
Use the attached example as reference I am pretty sure you will find useful for you application.
Hope this helps.
-Alí
747件の閲覧回数
elisamejia
Hello Ali,
I've been trying to do something similar. I need to change the focus state between 2 different buttons in order to change their colors according to some timer. However, whenever I call the D4D_FocusSet function or I use your code, the system goes to a halt and doesn't work.
I have all my buttons and schemes defined as INRAM but it isn´t working.
Can you help me with this?
Elisa
