eGUI - D4D_SetText doesn't work for Label object (v3.0)
818 次查看
Maciek
Contributor V
I'm updating label content (label text) depending on what button was pressed and some other data.
On each update, the updated (new) text overlaps the old text (or 'superposition' of previous texts) - I get superposition of both texts on the screen.
I would expect that the old text should be erased, and only the new one should be visible on screen.
I've checked both: D4D_SetText and D4D_LabelSetText.
There is no such problem with the Button widget...
I don't think this is the expected behaviour - or maybe I don't understand the widget behaviour ?
Maciek
553 次查看
LuisCasado
Change in d4d_user_cfg.h
#define D4D_LBL_FNT_PRTY_DEFAULT  ( D4D_FNT_PRTY_TRANSPARENT_YES_MASK )
By:
#define D4D_LBL_FNT_PRTY_DEFAULT  ( D4D_FNT_PRTY_TRANSPARENT_NO_MASK )
Luis
554 次查看
LuisCasado
By:
Luis
553 次查看
Maciek
Contributor V
Thanks for help. It works.
Maciek
