Where is K40Z memory map for peripherals?
569 次查看
LouisVRuffino
The datasheet refers to a Bit Manipulation Engine and the Analog section refers to a 12 bit ADC mode and a <12 bit mode.
Where are the programmers reference manual to these peripherals? where is the peripheral memory map for the device?
497 次查看
jeremyzhou
Hi Louis,
Actually, The K40 hasn't the BME (Bit Manipulation Engine) module after I checked the reference manual.
So I was wondering if you can upload the datasheet.
Ping
497 次查看
qqenchoi
sdcscfsdfvsaxdcaxvfdgvbdfgvedf
